Vista - Battery power notification-event log
Old 09-21-2007   #1 (permalink)
ksipp01
Is there an event that is logged to identify a switch to battery power? I
have enabled "kernal-power" but can't find a specific event that identifies
this. I would like to shut down a NAS by using this event to trigger a
scheduled task. the software that comes w/ my UPS doesn't have this
capability.
Any help is appreciated - thank you
Alter (auto) Power settings when plugged in or on Battery Power? Vista performance & maintenance
Low Battery Notification Vista General
battery notification Vista General
Battery Power Vista General
Battery power-RC2 Vista General
