| Guest | Nero problems? Which version is compatible with Vista please? I have just tried 7.10.10 and although it installs and runs fine, as soon as I try to navigate through it's file manager panel, it stops working completely!! cheers, Len |
| Guest | Re: Nero problems? Have you used the Nero's Update option? If so, you should get all the updates necessary to be fully Vista compatible. I Bleed Blue and Gold GO BEARS! "Len Cuff" <len.cuff@xxxxxx> wrote in message news:8018f3tnr6qqh7945bepv5vnqc34v2ok72@xxxxxx Quote: > Which version is compatible with Vista please? I have just tried > 7.10.10 and although it installs and runs fine, as soon as I try to > navigate through it's file manager panel, it stops working > completely!! > > > > cheers, > Len |
| Guest | Re: Nero problems? Len Cuff wrote: Quote: > Which version is compatible with Vista please? I have just tried > 7.10.10 and although it installs and runs fine, as soon as I try to > navigate through it's file manager panel, it stops working > completely!! > > > > cheers, > Len Works fine with Vista. Frank |
| Guest | Re: Nero problems? On Fri, 21 Sep 2007 17:48:27 GMT, Len Cuff <len.cuff@xxxxxx> wrote: Quote: >Which version is compatible with Vista please? I have just tried >7.10.10 and although it installs and runs fine, as soon as I try to >navigate through it's file manager panel, it stops working >completely!! > > > >cheers, > Len thing is that if I use Nero Express it works fine !!?? cheers, Len |
| Guest | Re: Nero problems? On Fri, 21 Sep 2007 17:48:27 GMT, Len Cuff <len.cuff@xxxxxx> wrote: Quote: >Which version is compatible with Vista please? I have just tried >7.10.10 and although it installs and runs fine, as soon as I try to >navigate through it's file manager panel, it stops working >completely!! > > > >cheers, > Len wondering if this is a permissions thing now? I updated from XP and had a few problems sharing netrowk drives but sorted all that. I have just realised that the problem only happens when I try to go INTO a directory which contains any files. I can navigate through directory structures which only have folders below them but as soon as I try to go into one which contains any files, Nero stops working! Nero Express is fine and I can use the normal Nero to burn ISO files fine. Any ideas please? cheers, Len |
| Nero problems in Event Viewer | Software | |||
| Nero Installations Problems | Vista General | |||
| Problems watching DVD with Nero | Vista music pictures video | |||
| RE: Problems watching DVD with Nero | Vista music pictures video | |||
| Problems using Nero 6 and 7 | Vista General | |||
