side by side error
  1. #1
    Nora Guest
    side by side error
    I am recieving the same error when I try to open both Windows Media Player
    and Windows Photo Gallery. This error has only occured in the past month when
    I first started using Vista both programs worked great now I get the
    following error :
    The application has failed to start because its side-by-side configuration
    is incorrect. Please see the application event log for more detail.
    In the event log there is nothing any help on how to fix this problem would
    be greatly appreciated.
  2. #2
    Ronnie Vernon MVP Guest
    Re: side by side error
    Nora
    The "side-by-side" component is associated with the Vista Windows Resource
    Protection (WRP). You may have a corrupted file in the SxS folder.
    To resolve this issue, use the System File Checker tool (SFC.exe) to repair
    these files.
    To do this, follow these steps:
    1. Open an elevated command prompt. To do this, click Start, click All
    Programs, click Accessories, right-click Command Prompt, and then click Run
    as administrator. If you are prompted for an administrator password or for a
    confirmation, type the password, or click Allow/Continue.
    2. Type the following command, and then press ENTER:
    sfc /scannow
    (The sfc /scannow command scans all protected system files and replaces
    incorrect versions with correct Microsoft versions.)
    This may take some time to run, so be patient.
    Let us know the results.
    Ronnie Vernon
    Microsoft MVP
    Windows Shell/User
    "Nora" <Nora@xxxxxx> wrote in message
    news:CACA5F62-722D-49E0-9AB4-1957922D71C6@xxxxxx
    > when
    > following error :
    > would
  3. #3
    Nora Guest
    Okay I tried to do the sfc scan it began the verification phase got to 43%
    then it says windows resource protection could not perform the requested
    operation. I tried it a couple more times just to see if it would work and it
    still comes up with that it can't perform the requested operation. Any
    suggestions on how to fix that or any other suggestions on how to fix the
    problem would be greatly appreciated.
    "Ronnie Vernon MVP" wrote:
    > Nora
    > these files.
    > sfc /scannow
    > Ronnie Vernon
    > Microsoft MVP
    > Windows Shell/User
    > > when
    > > following error :
    > > would
  4. #4
    Brink's Avatar
    Administrator
    Texas, USA
    64-bit Vista Ultimate SP2, Windows 7 Ultimate SP1, Windows 8 Enterprise
    Local Time: 10:07 PM
    usa us texas
    Quote Originally Posted by Nora View Post
    Hi Nora,
    You may need to run CHKDSK (Check Disk) first, then run the SFC /SCANNOW command. This tutorial will show you how to run the CHKDSK.
    http://www.vistax64.com/tutorials/67612-checkdisk.html
  5. #5
    Nora
    Try running sfc /scannow in Safe Mode.
    Reboot the computer and start tapping the F8 Key as soon as the computer
    starts to boot. Keep tapping the key until you see a black screen with a
    menu.
    Use the Arrow Keys to select Safe Mode. It will take a few minutes to boot
    to safe mode. Once there, follow the same steps to run the system file
    checker.
    Ronnie Vernon
    Microsoft MVP
    Windows Shell/User
    news:EFED0F25-35C9-4B89-BF76-4A7FDFC3A4E3@xxxxxx
    > it
    >> Nora
    >> Resource
    >> repair
    >> these files.
    >> Run
    >> for a
    >> sfc /scannow
    >> Ronnie Vernon
    >> Microsoft MVP
    >> Windows Shell/User
    >> >Player
    >> > month
    >> > when
    >> > following error :
    >> > configuration
    >> > would
  6. #6
    Nora Guest
    Okay also tried in safe mode and got the same message windows resource
    protection could not perform the requested operation and it comes up right
    after it gets to 43% in the verification process. Any other suggestions on
    how to fix this or the original problem would be greatly appreciated
    > Nora
    > menu.
    > checker.
    > Ronnie Vernon
    > Microsoft MVP
    > Windows Shell/User
    > > it
    > >> Nora
    > >> Resource
    > >> repair
    > >> these files.
    > >> Run
    > >> for a
    > >> sfc /scannow
    > >> Ronnie Vernon
    > >> Microsoft MVP
    > >> Windows Shell/User
    > >> >Player
    > >> > month
    > >> > when
    > >> > following error :
    > >> > configuration
    > >> > would
  7. #7
    Steven Wabik Guest
    well, what are some of the details that it gives you in the event log?
    knowing those may help. and what version of vista do you have?
    news:3190002B-7503-4FC6-A40A-5B9321DF3FE0@xxxxxx
    >> Nora
    >> menu.
    >> boot
    >> checker.
    >> Ronnie Vernon
    >> Microsoft MVP
    >> Windows Shell/User
    >> > 43%
    >> > requested
    >> > and
    >> > it
    >> > the
    >> >> Nora
    >> >> Resource
    >> >> repair
    >> >> these files.
    >> >> click
    >> >> Run
    >> >> for a
    >> >> sfc /scannow
    >> >> replaces
    >> >> Ronnie Vernon
    >> >> Microsoft MVP
    >> >> Windows Shell/User
    >> >> >Player
    >> >> > month
    >> >> > when
    >> >> > following error :
    >> >> > configuration
    >> >> > problem
    >> >> > would
  8. #8
    Nora Guest
    Thats the problem there is nothing in the event log about the side by side
    error which is one of the reason i have no idea how to fix it. Also I'm using
    Windows Vista 32-bit Home Premium edition.
    > >> Nora
    > >> menu.
    > >> boot
    > >> checker.
    > >> Ronnie Vernon
    > >> Microsoft MVP
    > >> Windows Shell/User
    > >> > 43%
    > >> > requested
    > >> > and
    > >> > it
    > >> > the
    > >> >> Nora
    > >> >> Resource
    > >> >> repair
    > >> >> these files.
    > >> >> click
    > >> >> Run
    > >> >> for a
    > >> >> sfc /scannow
    > >> >> replaces
    > >> >> Ronnie Vernon
    > >> >> Microsoft MVP
    > >> >> Windows Shell/User
    > >> >> >Player
    > >> >> > month
    > >> >> > when
    > >> >> > following error :
    > >> >> > configuration
    > >> >> > problem
    > >> >> > would
  9. #9
    Steven Wabik Guest
    do you have an OEM or retail edition of vista? if vista came preinstalled on
    your PC, try contcting the manufacturer of the PC for help. they might have
    a solution. or they may just tell you to reinstall the OS eventually...
    another idea is to update the OS with all the availible updates if you have
    not already done so. that always helps with something...
    news:3CD02856-C094-411D-AEC0-D3B6402068B7@xxxxxx
    > using
    >> > right
    >> > on
    >> >> Nora
    >> >> computer
    >> >> a
    >> >> menu.
    >> >> boot
    >> >> checker.
    >> >> Ronnie Vernon
    >> >> Microsoft MVP
    >> >> Windows Shell/User
    >> >> > to
    >> >> > 43%
    >> >> > requested
    >> >> > work
    >> >> > and
    >> >> > it
    >> >> > Any
    >> >> > fix
    >> >> > the
    >> >> >> Nora
    >> >> >> Resource
    >> >> >> to
    >> >> >> repair
    >> >> >> these files.
    >> >> >> All
    >> >> >> click
    >> >> >> Run
    >> >> >> or
    >> >> >> for a
    >> >> >> sfc /scannow
    >> >> >> replaces
    >> >> >> Ronnie Vernon
    >> >> >> Microsoft MVP
    >> >> >> Windows Shell/User
    >> >> >> >Media
    >> >> >> >Player
    >> >> >> > past
    >> >> >> > month
    >> >> >> > when
    >> >> >> > the
    >> >> >> > following error :
    >> >> >> > configuration
    >> >> >> > detail.
    >> >> >> > problem
    >> >> >> > would
  10. #10
    Nora Guest
    My vista came preinstalled on my Dell computer. I contacted dell tech support
    first they were of zero help they basically told me there was no fix and to
    restore my computer to a previous date. Also i have done all available
    updates. Thanks for the suggestions though. Have any more ideas how you think
    i can solve this would be greatly appreciated.
    > > using
    > >> > right
    > >> > on
    > >> >> Nora
    > >> >> computer
    > >> >> a
    > >> >> menu.
    > >> >> boot
    > >> >> checker.
    > >> >> Ronnie Vernon
    > >> >> Microsoft MVP
    > >> >> Windows Shell/User
    > >> >> > to
    > >> >> > 43%
    > >> >> > requested
    > >> >> > work
    > >> >> > and
    > >> >> > it
    > >> >> > Any
    > >> >> > fix
    > >> >> > the
    > >> >> >> Nora
    > >> >> >> Resource
    > >> >> >> to
    > >> >> >> repair
    > >> >> >> these files.
    > >> >> >> All
    > >> >> >> click
    > >> >> >> Run
    > >> >> >> or
    > >> >> >> for a
    > >> >> >> sfc /scannow
    > >> >> >> replaces
    > >> >> >> Ronnie Vernon
    > >> >> >> Microsoft MVP
    > >> >> >> Windows Shell/User
    > >> >> >> >Media
    > >> >> >> >Player
    > >> >> >> > past
    > >> >> >> > month
    > >> >> >> > when
    > >> >> >> > the
    > >> >> >> > following error :
    > >> >> >> > configuration
    > >> >> >> > detail.
    > >> >> >> > problem
    > >> >> >> > would
Page 1 of 2 12 LastLast
side by side error
vista 64 bit side by side config error msg for all programs! sotrain General Discussion 0 27 Oct 2009
Ultimate 64 Setpoint side by side configuration error newcitysue Software 1 09 May 2009
Adobe Reader - side by side configuration is inaccurate error Barbee Software 2 05 May 2009
Help for side-by-side config error...not written in Klingon Moraga Betty General Discussion 11 29 Mar 2009
Microsoft Flight Simulator X side-by-side configuration error Eddie Vista Games 5 17 Jul 2007
