| | shut down problems It may not be a Vista thing, but I'm not computer savvy enough to understand some of the other posts. My laptop will completely shut down, but it starts back up 2 seconds later. This seems to happen when the power cord is in. When I remove the power cord, it doesn't restart once it's shut down. I've checked the settings and nothing is set on restart. Any thoughts? Thanks in advance, Katie |
| | RE: shut down problems It would help if you told us how you shut your system down. Do you use a shortcut key combination, Start-Arrow(triangle)-Shut Down, Start-Power Button (left of lock icon), or the power button on your hardware, etc? You also might provide the status of these items. Control Panel, Power Options- when you open Power Options look on the left. There will be a question about what you want the power button (hardware button?) to do. What does yours say-shutdown, sleep...? Choose you power option. Select Change Advanced Power Option setting for your option. In a list you should see some mention of power button settings. Under one of its submenus you will see a choice for what you want the Start Power Button to do-sleep, shutdown, re-start. Tell us which option is selected. -- qfreed "mskate.austin" wrote: Quote: > It may not be a Vista thing, but I'm not computer savvy enough to understand > some of the other posts. My laptop will completely shut down, but it starts > back up 2 seconds later. This seems to happen when the power cord is in. > When I remove the power cord, it doesn't restart once it's shut down. I've > checked the settings and nothing is set on restart. Any thoughts? > > Thanks in advance, > Katie |
| ccSvcHst shut down problems | .NET General | |||
| Shut down problems resolved | Vista General | |||
| RC2 5744 Shut down Problems | Vista General | |||
| Shut down problems | Vista General | |||
| shut down problems | Vista installation & setup | |||
