Hi guys,
I've been searching the net high and low for solutions to my problem and no
such luck as yet! Firstly, I do understand that I am running a beta, and it
will be buggy. But it would seem that I am having some more dramas than most
people in regards to the blue screen errors.
My blue screen problem appears randomly, and I cannot see a pattern in it's
occurrence. The error report states the following:
Problem signature
Problem Event Name: BLUESCREEN
OS Version: 6.0.5384.2.0.0.256.1
Locale ID: 3081
Files that help describe the problem (some files may no longer be available)
Mini070306-06.dmp
sysdata.xml
Version.txt
View a temporary copy of these files
Warning: If a virus or other security threat caused the problem, opening a
copy of the files could harm your computer.
Extra information about the problem
BCCode: 1000008e
BCP1: C0000046
BCP2: 8208A531
BCP3: 996B57B4
BCP4: 00000000
OS Version: 6_0_5384
Service Pack: 0_0
Product: 256_1
So... This error is the same error that is always recorded from what I can
see (all error logs say the same thing). I don't understand what exactly is
causing the error?
I am also running the recommended avast! virus protection if that helps...
Any ideas... anyone??
Thanks for your time!
-Marshall
