| | #11 (permalink) |
| | RE: Kodak Easyshare and Vista, was Permissions problem Wow. This is great info. Thanks for the help Frank. I'll poke around the web to see if I can find those utilities mentioned in the tech support instructions and get on this later today. Thanks! Brian "Frank M. Greco" wrote: Quote: > Brian wrote: Quote: > > Frank- > > > > What registry key values are you modifying to get your Kodak Eastshare 5500 > > printer to work? I bought the 5100 a few months ago and it refuses to work > > with 64-bit Vista. Kodak tech support is virtually non-existent. > > > > > > Thanks. > > Brian > Hi Brian. I simply went through the whole registry, searching for > anything to do with Kodak Easy share, and removing what I found (when I > was allowed to remove values). I did this under the true adminisator > account. However, it did not work all that well, and I could not use the > Kodak AiO software. I finally got a resolution from Kodak Customer > Support. It's long, but it did work: > > ......Begin..... > > Thank you for your patience, while we work through the issue you are > having with your printer. I have a possible resolution to your issue, > that I would like you to attempt. Below you will find some instructions > for using a few utilities to clear the existing software off of your > computer. This may allow us to reinstall it correctly. The procedure > looks long, however, I have tried to make each step as short as > possible. Prior to beginning, please temporarily turn off, or disable, > any virus, or protection software, on your computer. > > > In addition to the process below, we suspect that the problem is related > to your firewall. It is most likely 'remembering' the Kodak scanner > driver from the original failed attempt and still viewing it as an > attack of some sort and blocking the new install. If you can find a way > to remove the Kodak entry in your firewall configuration, then the Kodak > software should install properly. If you are using the Microsoft > Firewall, Click START, and then select CONTROL PANEL, Open the SECURITY > CENTER icon, Open the WINDOWS FIREWALL icon from the Security Center, > and then Click the EXCEPTIONS TAB. Check the box for the Kodak program > to unblock and click OKAY. > > > > The steps are as follows. > > 1. Disconnect your printer from the computer. Remove the Kodak > install CD from your computer. > > 2. Save two attached files to the desktop of your computer. One > is named KODAKUTILITIES.EXE1 and the other is ClearN7_1.exe1. > > If the files show up on your desktop as "KODAKUTILITIES" without > the ".EXE1" at the end, follow steps 3 - 9. If the files show up with > thier full name of "KODAKUTILITIES.EXE1", then skep ahead to step 10. > > > 3. Click on the START button. > 4. Choose CONTROL PANEL. You may have to select SETTINGS first, > and then CONTROL PANEL. > 5. Go to Tools in the menu bar above and select FOLDER OPTIONS. > 6. Select the VIEW tab. > 7. Deselect the option for HIDE EXTENSIONS FOR KNOWN FILE TYPES. > 8. Click OK. > 9. Close all windows. > > > 10. Rename the KODAKUTILITIES.EXE1 file. Change its name to > KODAKUTILITIES.EXE. > 11. Double click on the KODAKUTILITIES.EXE file. > 12. A window will appear. Choose the UNZIP option. > 13. Once the file says that it is unzipped, choose the OK option. > 14. Choose the CLOSE option. > 15. Close all windows. > > > 16. Open MY COMPUTER. > 17. Open your C DRIVE. > 18. Open the KODAKUTILITIES folder. > 19. Open the AIO_CLEANUP folder. > > > 20. Rename the following files. > a. cleanup.bat1 ---- > cleanup.bat > b. KodakSvc.exe1 ---- > KodakSvc.exe > c. regClean.reg1 ---- > regClean.reg > d. UNINST.VBS1 ---- > UNINST.VBS > > 21. Double Click on the cleanup.bat file(you need to Run As > Administrator in order for this to work--FMG), and follow the prompts. > 22. When a message appears stating that DRIVER UNINSTALLED!, > click OK. > 23. Close all windows. > > > > 24. Rename the ClearN7_1.exe1 file by removing the '1' at the > end. Change its name to ClearN7_1.exe. > > 25. Double Click on the ClearN7_1.exe file (you need to Run As > Administrator in order for this to work--FMG), and follow the prompts. > 26. When this utility is completed, reboot the computer. > > > 27. Open MY COMPUTER. > 28. Open your C DRIVE. > 29. Open the KODAKUTILITIES folder. > 30. Open the MicrosoftCleanUp folder. > > > 31. Rename the following file. > a. msicuu2.exe1 ---- > msicuu2.exe > > > 32. Double Click on the msicuu2.exe file (you need to Run As > Administrator in order for this to work--FMG), and follow the prompts > for installing the Microsoft Clean Up Utility. > 33. When the installation is complete, close all windows. > > > 34. Click START, choose PROGRAMS, and choose WINDOWS (or) > MICROSOFT INSTALL CLEAN UP. > > A Microsoft Installer Clean Up Window will appear. It will have a list > of installed packages on your computer. Some of the items, in the list > may be remnants of our Kodak Software. We will be using the Microsoft > Installer Clean Up to remove these remnants. > > Please note that the program components you are about to remove using > the “MICROSOFT Installer Cleanup Utility” are specific to Kodak > EasyShare software and will not affect the performance of other software > programs on your system. > > Kodak is not responsible for any damage caused by use of “MICROSOFT > Installer Cleanup Utility” and strongly recommends backing up the system > registry. (http://support.microsoft.com/kb/322756/EN-US) – Link to > registry backup instructions, if needed. > > > 35. Look through the Microsoft Installer Clean Up list for the > following items. > > Aiofw > Aioocr > Aioprnt > Aioscnnr > Aspi > CardRd81 > Center > CCHelp > CCScore > CR2 > ESSAdpt > ESSANUP > ESSBrwr > ESSCAM > ESSCDBK > ESScore > ESSCT > ESSEMAIL > ESSgui > ESShelp > ESSini > ESSONIC > ESSPCD > ESSPDock > ESSShare > ESSSONIC > ESSstore > ESSTOOLS > ESSTUTOR > ESSvatgt > ESSvcpt > ESSvpaht > ESSvpot > HelpCtr > HLPCCTR > HLPIndex > HLPPDOCK > HLPRFO > HLPSFO > HLPSHARE > Ksdip > KSU > Notifier > OfotoXMI > OttBP > OTTBPSDK > PCADDIN > PCDHELP > PCDLNCH > SFR > SFR2 > SHASTA > SKIN0001 > SKINXSDK > VCAMCEN > VPRINTOL > VPRINTOL > WIRELESS > > 36. If an item in the above list is found, highlight it, and > choose the REMOVE button. > a. DO NOT REMOVE ANYTHING THAT IS NOT ON THE LIST. > b. REMOVE ITEMS ONE AT A TIME. > c. IF AN ITEM IS NOT IN THE LIST, CONTINUE TO THE NEXT ITEM. > > 37. Once you have removed the items from the above list, close > all windows. > > 38. Reboot the computer. > > 39. Turn off any anti-virus and firewall if possible. > > 40. Attempt to reinstall the software from the WEB by using > inserting the CD and selecting the WEB option. > > 41. Choose NOT to register the software. > > 42. Select TYPICAL install if you want to install all the > EasyShare software along with the drivers. > If you only want to use the printer and scanner select a CUSTOM > install and then select "do not install" for each of the choices that > appear. > > 43. After the install is completed, restart your computer and > turn ON the printer. > > 44. If your printer is succesfully connected, you can update it's > firmware. See the attached file named: fw_5000_801.exe1. In order to run > it you will need to rename it by removing the last digit - the number > '1'. Then simply double-click on it and follow the prompts until it is > complete. > > ......END..... > > Like I said, it did work, and I can use the printer/scanner along with > the AiO software. however, there is still one problem have not been able > to fix, that being when I open the AiO software, running as > administration or not, it messes up the colors on my desktop. Once the > close the program, the color returns to normal. > Here's an explanation (from Windows) of why it happened: > > .....BEGIN..... > > If you receive a message that some visual elements, such as window frame > transparency, have been turned off, or if you receive a message that the > color scheme has been changed to Windows Vista Basic, one of the > following might have happened: > > A program that you're running is incompatible with the Windows Aero > color scheme (this is most likely the problem---FMG). When you run a > program that is incompatible with the Windows Aero color scheme, some > visual elements are automatically turned off. When the program is no > longer running, the visual elements that were turned off will be turned > on again automatically. > > Your computer does not have enough memory to run all of the programs > that you have open and also run the Windows Aero color scheme (I have > plenty of memory--FMG). Try closing some windows or changing your color > scheme to Windows Vista Basic (made no difference--FMG). If Windows > automatically changed your color scheme to Windows Vista Basic, and you > want to change it back to Windows Aero after closing some windows, > follow these steps. > > ....END... > > I can live with the color distortion, but I'd sure lke to know why it's > happening. > Frank > |
| | #12 (permalink) |
| | Re: Kodak Easyshare and Vista, was Permissions problem Brian, email me directly and I'll send them to you. My addy is phrankg@xxxxxx Frank |
| problem with Permissions- can anyone please help | Vista General | |||
| Permissions Problem | Vista networking & sharing | |||
| Permissions problem? | Vista General | |||
| Permissions problem? | Vista installation & setup | |||
| permissions problem? | Vista file management | |||
