Vista Tutorial - Remote Desktop Connection Issue
Old 09-22-2007   #1 (permalink)
DaveG
Guest
I'm trying to help mom with her new computer... Both are running Vista, but
when I try to connect, it just times out. I have removed my router as well
as disabled Windows Live OneCare Firewall. Is there some other trick to get
this to work? I get the message "The error message: The person you are
trying to help might have closed Remote Assistance" even though remote
assistance was never closed. Any help greatly appreciated.
Old 09-22-2007   #2 (permalink)
Robert Firth
Guest
Re: Remote Desktop Connection Issue
I suspect that the you may have closed the remote assistance window on the
other computer... just as it says. I did the same thing. When you create an
remote assistance invitation and it is sent by email or whatever way you
send it - don't close that window on the computer that you are going to
assist with. I know what you want to do is press close, or finish, or
whatever is on that last page of the wizard but don't.
I think this is so that you can't randomly start a remote assistance
connection whenever you want just because you have an invitation for that
computer - security issue.
Robert Firth
"DaveG" <DaveG@xxxxxx> wrote in message
news:8CA3C462-3AC8-483E-AB60-16741130D3C9@xxxxxx
> but
> well
> get
Old 09-23-2007   #3 (permalink)
DaveG
Guest
Thanks for the response. We actually tried several times, and I made sure
she didnt' close the "waiting for call" window. It seems to be some other
issue I think.
> Robert Firth
> > but
> > well
> > get
Old 09-23-2007   #4 (permalink)
Robert Miles
Guest
newsB97AB93-CDA3-4480-AD3E-0FD77F93E2AE@xxxxxx
> issue I think.
>> the
>> an
>> Robert Firth
>> > but
>> > well
>> > to
>> > get
>> > are
Which version of Vista? I think I heard that one or both of the Home
versions
can't be used on one end of the connection.
invalid connection file on remote desktop connection Vista General
Remote Desktop Connection issue Vista networking & sharing
Fixed! Remote Desktop Connection (RDC) SLOW/NO Connection Issue Vista networking & sharing
Vista SP1 Remote Desktop Connection issue Vista General
Can't login to remote comp. using Remote Desktop Connection on Vis Vista account administration
