| Guest | Retail 32bit vista Home Premium upgrade to 64 bit Home Premium - H How can you upgrade to 64bit Home Premium Vista from a retail version 32 bit Home Premium version that cam with the PC? |
| Guest | Re: Retail 32bit vista Home Premium upgrade to 64 bit Home Premium - H Yes, but you can't do an in-place upgrade. You will have to do a clean install, which you can do with a 64 bit upgrade copy. -- Robert Firth "rrdToledo" <rrdToledo@xxxxxx> wrote in message news:1AEC61D0-2820-4C52-A0EF-72889E7B2E9A@xxxxxx Quote: > How can you upgrade to 64bit Home Premium Vista from a retail version 32 > bit > Home Premium version that cam with the PC? |
| Guest | Re: Retail 32bit vista Home Premium upgrade to 64 bit Home Premium - H If Vista came installed on the PC, it is not a retail (boxed) version, it is an OEM version and you will have to contact the PC manufacturer to see if you can obtain the 64-bit version of Vista I Bleed Blue and Gold GO BEARS! "rrdToledo" <rrdToledo@xxxxxx> wrote in message news:1AEC61D0-2820-4C52-A0EF-72889E7B2E9A@xxxxxx Quote: > How can you upgrade to 64bit Home Premium Vista from a retail version 32 bit > Home Premium version that cam with the PC? |
| Administrator | Re: Retail 32bit vista Home Premium upgrade to 64 bit Home Premium - H If you do have a retail version of the 32 bit Vista, then you can order the 64 bit Vista from Microsoft at this link. It costs $9.99 for S & H. The Ultimate Vista is the only one that comes with both the 32 and 64 bit versions. Windows Vista Alternate Media Hope this helps, Shawn |
| Guest | Re: Retail 32bit vista Home Premium upgrade to 64 bit Home Premium Thank you all "brink" wrote: Quote: > > Cal Bear '66;461815 Wrote: Quote: > > If Vista came installed on the PC, it is not a retail (boxed) version, > > it is an > > OEM version and you will have to contact the PC manufacturer to see if > > you can > > obtain the 64-bit version of Vista > > > > > > I Bleed Blue and Gold > > GO BEARS! Quote: > > > > How can you upgrade to 64bit Home Premium Vista from a retail version > > 32 bit > > Home Premium version that cam with the PC? > > > > > In addition to Cal Bear for a OEM Vista: > If you do have a retail version of the 32 bit Vista, then you can order > the 64 bit Vista from Microsoft at this link. It costs $9.99 for S & H. > The Ultimate Vista is the only one that comes with both the 32 and 64 > bit versions. > > 'Windows Vista Alternate Media' > (http://www.microsoft.com/windowsvist...a/default.mspx) > > Hope this helps, > Shawn > > > -- > brink > > *There are no dumb questions, just the people that do not ask them.* > WWW.VISTAX64.COM (\"HTTP://WWW.VISTAX64.COM\") > *Please post feedback to help others.* > |
| | #6 (permalink) |
| Administrator | Re: Retail 32bit vista Home Premium upgrade to 64 bit Home Premium |
| | #7 (permalink) |
| Guest | Re: Retail 32bit vista Home Premium upgrade to 64 bit Home Premium I got with the PC make and they are going to shipme a 64bit disk for free for my vista version---thank you for your help "Cal Bear '66" wrote: Quote: > If Vista came installed on the PC, it is not a retail (boxed) version, it is an > OEM version and you will have to contact the PC manufacturer to see if you can > obtain the 64-bit version of Vista > > > I Bleed Blue and Gold > GO BEARS! > > > "rrdToledo" <rrdToledo@xxxxxx> wrote in message > news:1AEC61D0-2820-4C52-A0EF-72889E7B2E9A@xxxxxx Quote: > > How can you upgrade to 64bit Home Premium Vista from a retail version 32 bit > > Home Premium version that cam with the PC? > |
| Upgrade: Home Premium to Ultimate 32bit | Windows Updates | |||
| How do i upgrade an eval Home Premium to a Retail Ultimate? | Vista installation & setup | |||
| Vista Home Premium 32bit Upgrade to Vista Ultimate 64bit | Vista installation & setup | |||
| "Upgrade" Vista Home Premium (OEM) to Vista Home Premium (Retail Upgrade) | Vista General | |||
| Vista Home Premium 32bit via Vista Express Upgrade | Vista General | |||
