Reverse Stereo? Left to Right?
  1. #1
    Peter Guest
    Hi
    Can I make Vista to reverse the stereo sound -- having the left sound play
    on the right side and vice versa?
    I have external speakers hooked up to my computer, and due to the short
    cables on the speakers, it works better if the left speaker is on the right,
    but thus my stereo is wrong...
    Any ideas?
  2. #2
    Carey Frisch [MVP] Guest
    Re: Reverse Stereo? Left to Right?
    Just reverse the physical placement of your speakers.
    Carey Frisch
    Microsoft MVP
    Windows Shell/User
    "Peter" <Peter@xxxxxx> wrote in message
    news:0465AACA-35BE-41C0-A868-BED567AE8EC6@xxxxxx
    Hi
    Any ideas?
  3. #3
    jonathan perreault Guest
    advice would be get small extension cable i don't think you can but i never
    tried
    Jonathan Perreault
    Personnal Advice To You:
    #1: Do Not Undermine Windows's Work, Or It'll Undermine You As A User.
    #2: Torture Windows (Any) Now Before It Tortures You
    Best Comments From Users:
    No Matter The Problem Even With Linux, It's Microsoft's And Windows's Faults
    A common mistake that people make when trying to design something completely
    foolproof is to underestimate the ingenuity of complete fools.
    > Hi
    > right,
    > Any ideas?
  4. #4
    don't think that's what she/he meant.
    Jonathan Perreault
    "Carey Frisch [MVP]" <cnfrisch@xxxxxx> wrote in message
    news:434FC804-3C0A-4F4C-A938-8DBAB050B0E6@xxxxxx
    > Carey Frisch
    > Microsoft MVP
    > Windows Shell/User
    > Hi
    > right,
    > Any ideas?
  5. #5
    Val Guest
    yes, such cables exist - often sold as extensions for headsets.
    Try a Radio Shack or other electronics store.
    Val
    "jonathan perreault" <jonperreault@xxxxxx> wrote in message
    news:F3597D85-8D85-411C-89BE-7E6A40AAE575@xxxxxx
    tried
    Jonathan Perreault
    > Hi
    > right,
    > Any ideas?
  6. #6
    Lang Murphy Guest
    > Hi
    > right,
    > Any ideas?
    You should be able to get extension cables for just about any type of
    connector. Most PC speaker systems use mini-jacks... you should be able to
    find a mini-jack extension at your local Radio Shack.
    Lang
  7. #7
    vin Guest
    Hi.. I have not dealt with Vista yet. But on my XP machine, I'm using
    Realtek sound card and the drivers I got comes with a utility. Maybe you
    should find out the manufacturer of your sound card and download the drivers
    plus utility to fine tune your sound card, if such utility exist. Just a
    thought.
    Regards.
    > Hi
    > right,
    > Any ideas?
  8. #8
    Gene K Guest
    You can buy either longer cables or buy adapters (female jacks at both ends)
    to create your own longer cables.
    Gene K
    > never tried
    > Jonathan Perreault
    > Faults
    > completely foolproof is to underestimate the ingenuity of complete fools.
    >> Hi
    >> play
    >> right,
    >> Any ideas?
  9. #9
    what i meant by i don't think you can is i don't think you can do what you
    were talking about but like i was saying in the first place which no one is
    answering your answer is that you are better off with a extension cable
    Jonathan Perreault
    > never tried
    > Jonathan Perreault
    > Faults
    >> Hi
    >> play
    >> right,
    >> Any ideas?
  10. #10
    HeyBub Guest
    Peter wrote:
    > Hi
    > play on the right side and vice versa?
    > short cables on the speakers, it works better if the left speaker is
    > on the right, but thus my stereo is wrong...
    Reminds me of the sign scrawled on the wall behind the commode:
    "If you can read this, report to the Student Health Center to have your head
    reversed."
Page 1 of 2 12 LastLast
Reverse Stereo? Left to Right? problems?
Reverse DNS query jad SBS Server 10 11 Feb 2010
reverse list Ben Live Messenger 4 23 Jan 2010
Reverse List? Joao Santos Live Messenger 2 20 Dec 2009
Get-Alias and its reverse hasten PowerShell 0 25 Feb 2008
can'r reverse language Dennis Landstedt Vista mail 0 23 Jan 2008
