| | Is this how Solution Center should work or i found a bug? Hello Everybody! Not sure if this is a good place to report bugs (tried to search connect.microsoft.com for Vista feedback without success). So the problem happens when an executable fails to load (for eg. because of missing dll) or freeze and has specific name like a.exe or b.exe Vista starts looking for solution and telling me "Microsoft detected the (depends on filename) Virus on your Computer". I think it is a bug, as in normal case these systems signature based, and not just working with filenames as a.exe can be a totally normal application (which freeze or fail to load). Here is a short movie, when i try to compile a c program which only add 1+1 via a dll function: http://www.bcsaba.net/~bcsaba/vista/solution.htm Thanks: Csaba |
| I found the error for my WMP, but need the solution | Vista General | |||
| Solution found | Vista security | |||
| Solution cannot be found | Vista General | |||
| I found the solution | Vista General | |||
| Solution Found Now What? | Vista installation & setup | |||
