Vista - System restore task running but....
Old 09-25-2007   #1 (permalink)
Yvonne
Hi
Might be missing something really obvious here & I'm not the most technical
of bods so please be kind with your responses
When I go to run a System restore my restore point options are limited to
the ones that are visible are the ones that appear are those that occur when
there's a Window Update or I've installed something. The ones that take place
daily via my Scheduled Tasks are not visible. Should they be? I want them to
be!
I've checked my Scheduled Tasks & the SR does take place at the designated
time.
Any ideas or am I expecting something that can't happen - nothing new there
them
Yvonne
Old 09-25-2007   #2 (permalink)
Yvonne
RE: System restore task running but....
My apologies for not checking before sending, as not much of the above makes
sense. Try again.
The Restore Points that are visible are those that were created by the
system prior to a Windows Update or if I've installed something. Were are the
daily ones?
Thanks in advance
Yvonne
Old 09-25-2007   #3 (permalink)
Michael Solomon
Re: System restore task running but....
"Yvonne" <Yvonne@xxxxxx> wrote in message
news:174A4AF5-35FD-4D51-AD96-73FA9A1D430A@xxxxxx
Quote:
> Hi
> technical
> when
> place
> to
> be!
> time.
> there
> them
> Yvonne
First, are you dual booting with Windows XP as such a setup will delete
Vista restore points? Second, are you running any system cleanup utilities
or do you have some application that has such a function that runs
periodically as it might be deleting restore points?
Usually, the scheduled SR would show in System Restore as "System Scheduled
Checkpoint."
Michael Solomon
Backup is a PC user's best friend
DTS-L.Org: http://www.dts-l.org/
Old 09-26-2007   #4 (permalink)
Bert Kinney
Missing Restore Points/Shadow Copies in Windows Vista:
http://bertk.mvps.org/html/missingrpv.html
Dual Booting Windows Vista & Windows XP:
http://bertk.mvps.org/html/dualboot.html
Regards,
Bert Kinney MS-MVP Shell/User
Member: http://dts-l.org
Yvonne wrote:
Quote:
> Hi
> be!
> time.
> them
> Yvonne
Task image corrupt?? System restore Vista General
System Restore does not run via Task Scheduler General Discussion
System Restore Task - Change Automatic Restore Point Schedule Tutorials
System restore already running Vista General
Task Scheduler question (System Restore) Vista performance & maintenance
