| | Backing Up Problem I am running Vista Ultimate 64-bit, and I have a small problem. I am trying to use the built-in backup program in the Backup and Restore Center, but I am running into this error message when I attempt to use it: --------------------------- Windows Backup --------------------------- Windows could not find backup devices on your computer. The following information might explain why this problem occurred: Catastrophic failure (0x8000FFFF) Please close the backup application and try again. In the Backup and Restore Center, I can start the "back up files" wizard, and it recognizes my backup source, but the "back up computer" wizard does not. Only the "back up computer" causes the error message. Also, in my event viewer I have these three errors: Source: VSS Event ID: 8193 Volume Shadow Copy Service error: Unexpected error calling routine CoCreateInstance. hr = 0x80040154. Operation: Gathering Writer Data Executing Asynchronous Operation Context: Execution Context: Requestor Current State: GatherWriterMetadata Source: VSS Event ID: 13 Volume Shadow Copy Service information: The COM Server with CLSID {faf53cc4-bd73-4e36-83f1-2b23f46e513e} and name VSSEvent cannot be started. [0x80070057] Operation: Gathering Writer Data Executing Asynchronous Operation Context: Execution Context: Requestor Current State: GatherWriterMetadata Source: VSS Event ID: 34 Volume Shadow Copy Service error: The VSS event class is not registered. This will prevent any VSS writers from receiving events. This may be caused due to a setup failure or as a result of an application's installer or uninstaller. Operation: Gathering Writer Data Executing Asynchronous Operation Context: Execution Context: Requestor Current State: GatherWriterMetadata Additional Info: I have plenty of free sace for a backup in several different areas, and they are all detected in explorer and I can access them all freely. Volume Shadow Copy, Windows Backup, Virtual Disk, RPC, and DCOM are all running. I have disabled a few other services since I installed Vista though so that could be the issue. I searched the boards and found a possible solution to my problem by stopping System Restore and reenabling it and then creating a restore point. However, when I tried to create a new restore point, I received this error: Quote: --------------------------- System Protection --------------------------- The restore point could not be created for the following reason: Catastrophic failure (0x8000FFFF) Please try again. I tried to be as thorough as possible in giving you all as much information as I can. And I tried to be as organized as I could with my post on these forums. But if you have any more question then please ask. Thanks |
| Vista Home Premium (32), XP Pro (32), Vista Ultimate (64) | Re: Backing Up Problem I've found another person who had (and solved) this same problem. It may or may not work for you, but I would try running chkdsk. According to them, it was a corrupted area in the NTFS file system causing that error. (if you don't know--you probably do--but just in case, you can run chkdsk in command prompt, by typing: chkdsk /f) BE CAUTIOUS ABOUT THIS The person also said that after the disk check, a windows .dll had become corrupted. This may or may not happen to you as well, but if you don't have a way to replace a .dll (e.g. a backup hard drive or the vista installation disc) then I would stay away from a disk check since it would permanently disable your computer until you got that file replaced. After replacing the .dll (which is not hard, provided you have something with a clean version of the file), the system should run fine. Hopefully, you won't have the same problem if you do decide to run chkdsk. |
| | Re: Backing Up Problem I ran chkdsk and it found no problems. However, I did notice something (unrelated to chkdsk) that was acting funny. When I was booting my computer, I noticed some odd screens popup. They only lasted a split second so I could not read them. They may or may not be related to my problem, but I figure I might as well post it. I enabled bootlogging, and here is the log: Microsoft (R) Windows (R) Version 6.0 (Build 6000) 9 27 2007 00:47:06.500 Loaded driver \SystemRoot\system32\ntoskrnl.exe Loaded driver \SystemRoot\system32\hal.dll Loaded driver \SystemRoot\system32\kdcom.dll Loaded driver \SystemRoot\system32\PSHED.dll Loaded driver \SystemRoot\system32\CLFS.SYS Loaded driver \SystemRoot\system32\CI.dll Loaded driver \SystemRoot\system32\drivers\Wdf01000.sys Loaded driver \SystemRoot\system32\drivers\WDFLDR.SYS Loaded driver \SystemRoot\system32\drivers\acpi.sys Loaded driver \SystemRoot\system32\drivers\WMILIB.SYS Loaded driver \SystemRoot\system32\drivers\msisadrv.sys Loaded driver \SystemRoot\system32\drivers\pci.sys Loaded driver \SystemRoot\system32\drivers\volmgr.sys Loaded driver \SystemRoot\System32\drivers\mountmgr.sys Loaded driver \SystemRoot\system32\drivers\pciide.sys Loaded driver \SystemRoot\system32\drivers\PCIIDEX.SYS Loaded driver \SystemRoot\System32\drivers\volmgrx.sys Loaded driver \SystemRoot\system32\drivers\atapi.sys Loaded driver \SystemRoot\system32\drivers\ataport.SYS Loaded driver \SystemRoot\system32\DRIVERS\nvstor64.sys Loaded driver \SystemRoot\system32\DRIVERS\storport.sys Loaded driver \SystemRoot\system32\drivers\fltmgr.sys Loaded driver \SystemRoot\system32\drivers\fileinfo.sys Loaded driver \SystemRoot\System32\Drivers\DefragFS.sys Loaded driver \SystemRoot\system32\drivers\ndis.sys Loaded driver \SystemRoot\system32\drivers\msrpc.sys Loaded driver \SystemRoot\system32\drivers\NETIO.SYS Loaded driver \SystemRoot\System32\Drivers\Ntfs.sys Loaded driver \SystemRoot\System32\Drivers\ksecdd.sys Loaded driver \SystemRoot\system32\drivers\volsnap.sys Loaded driver \SystemRoot\System32\Drivers\spldr.sys Loaded driver \SystemRoot\System32\drivers\partmgr.sys Loaded driver \SystemRoot\System32\Drivers\mup.sys Loaded driver \SystemRoot\System32\drivers\ecache.sys Loaded driver \SystemRoot\System32\DRIVERS\fvevol.sys Loaded driver \SystemRoot\system32\drivers\disk.sys Loaded driver \SystemRoot\system32\drivers\CLASSPNP.SYS Loaded driver \SystemRoot\system32\drivers\crcdisk.sys Loaded driver \SystemRoot\system32\DRIVERS\tunnel.sys Loaded driver \SystemRoot\system32\DRIVERS\tunmp.sys Loaded driver \SystemRoot\system32\DRIVERS\amdk8.sys Loaded driver \SystemRoot\system32\DRIVERS\usbohci.sys Loaded driver \SystemRoot\system32\DRIVERS\usbehci.sys Loaded driver \SystemRoot\system32\DRIVERS\cdrom.sys Loaded driver \SystemRoot\system32\drivers\ctoss2k.sys Loaded driver \SystemRoot\system32\drivers\ctprxy2k.sys Loaded driver \SystemRoot\system32\drivers\ctaud2k.sys Loaded driver \SystemRoot\system32\drivers\ksthunk.sys Loaded driver \SystemRoot\system32\DRIVERS\nvmfdx64.sys Loaded driver \SystemRoot\System32\drivers\dxgkrnl.sys Loaded driver \SystemRoot\system32\DRIVERS\nvlddmkm.sys Loaded driver \SystemRoot\system32\DRIVERS\serial.sys Loaded driver \SystemRoot\system32\DRIVERS\serenum.sys Loaded driver \SystemRoot\system32\DRIVERS\i8042prt.sys Loaded driver \SystemRoot\system32\DRIVERS\L8042Kbd.sys Loaded driver \SystemRoot\system32\DRIVERS\kbdclass.sys Loaded driver \SystemRoot\system32\DRIVERS\msiscsi.sys Loaded driver \SystemRoot\system32\DRIVERS\rasl2tp.sys Loaded driver \SystemRoot\system32\DRIVERS\ndistapi.sys Loaded driver \SystemRoot\system32\DRIVERS\ndiswan.sys Loaded driver \SystemRoot\system32\DRIVERS\raspppoe.sys Loaded driver \SystemRoot\system32\DRIVERS\raspptp.sys Loaded driver \SystemRoot\system32\DRIVERS\rdpdr.sys Loaded driver \SystemRoot\system32\DRIVERS\termdd.sys Loaded driver \SystemRoot\system32\DRIVERS\mouclass.sys Loaded driver \SystemRoot\system32\DRIVERS\swenum.sys Loaded driver \SystemRoot\system32\DRIVERS\mssmbios.sys Loaded driver \SystemRoot\system32\DRIVERS\umbus.sys Loaded driver \SystemRoot\system32\DRIVERS\usbhub.sys Loaded driver \SystemRoot\system32\drivers\ha20x2k.sys Loaded driver \SystemRoot\system32\drivers\emupia2k.sys Loaded driver \SystemRoot\system32\drivers\ctsfm2k.sys Loaded driver \SystemRoot\system32\CTHWIUT.DLL Loaded driver \SystemRoot\system32\CT20XUT.DLL Loaded driver \SystemRoot\system32\CTEXFIFX.DLL Loaded driver \SystemRoot\System32\Drivers\NDProxy.SYS Loaded driver \SystemRoot\system32\DRIVERS\klif.sys Loaded driver \SystemRoot\System32\Drivers\Fs_Rec.SYS Loaded driver \SystemRoot\System32\Drivers\Null.SYS Did not load driver \??\C:\Windows\system32\drivers\OxFWLF.sys Loaded driver \SystemRoot\System32\drivers\vga.sys Loaded driver \SystemRoot\System32\DRIVERS\RDPCDD.sys Loaded driver \SystemRoot\system32\drivers\rdpencdd.sys Loaded driver \SystemRoot\System32\Drivers\Msfs.SYS Loaded driver \SystemRoot\System32\Drivers\Npfs.SYS Loaded driver \SystemRoot\System32\DRIVERS\rasacd.sys Loaded driver \SystemRoot\System32\drivers\tcpip.sys Loaded driver \SystemRoot\system32\DRIVERS\tdx.sys Loaded driver \SystemRoot\system32\DRIVERS\kl1.sys Loaded driver \SystemRoot\system32\DRIVERS\smb.sys Loaded driver \SystemRoot\system32\drivers\afd.sys Loaded driver \SystemRoot\System32\DRIVERS\netbt.sys Loaded driver \SystemRoot\system32\DRIVERS\pacer.sys Loaded driver \SystemRoot\system32\DRIVERS\klim6.sys Loaded driver \SystemRoot\system32\DRIVERS\netbios.sys Loaded driver \SystemRoot\system32\DRIVERS\wanarp.sys Loaded driver \SystemRoot\system32\DRIVERS\rdbss.sys Loaded driver \SystemRoot\system32\drivers\nsiproxy.sys Loaded driver \??\C:\Program Files (x86)\UltraISO\drivers\ISODrv64.sys Loaded driver \SystemRoot\System32\Drivers\dfsc.sys Loaded driver \SystemRoot\system32\DRIVERS\usbccgp.sys Loaded driver \SystemRoot\system32\DRIVERS\usbscan.sys Loaded driver \SystemRoot\system32\DRIVERS\usbprint.sys Loaded driver \SystemRoot\system32\DRIVERS\USBSTOR.SYS Loaded driver \SystemRoot\system32\DRIVERS\hidusb.sys Loaded driver \SystemRoot\system32\DRIVERS\LHidFilt.Sys Loaded driver \SystemRoot\system32\DRIVERS\mouhid.sys Loaded driver \SystemRoot\system32\DRIVERS\LMouFilt.Sys Loaded driver \SystemRoot\system32\DRIVERS\monitor.sys Loaded driver \SystemRoot\system32\drivers\luafv.sys Loaded driver \SystemRoot\system32\drivers\drmkaud.sys Loaded driver \SystemRoot\system32\DRIVERS\irda.sys Loaded driver \SystemRoot\system32\DRIVERS\lltdio.sys Loaded driver \SystemRoot\system32\DRIVERS\rspndr.sys Loaded driver \SystemRoot\system32\drivers\HTTP.sys Loaded driver \SystemRoot\system32\DRIVERS\bowser.sys Loaded driver \SystemRoot\System32\drivers\mpsdrv.sys Loaded driver \SystemRoot\system32\DRIVERS\mrxsmb.sys Loaded driver \SystemRoot\system32\DRIVERS\mrxsmb10.sys Loaded driver \SystemRoot\system32\DRIVERS\mrxsmb20.sys Loaded driver \SystemRoot\system32\drivers\peauth.sys Loaded driver \SystemRoot\System32\Drivers\secdrv.SYS Loaded driver \SystemRoot\System32\drivers\tcpipreg.sys Loaded driver \SystemRoot\system32\DRIVERS\cdfs.sys Note: The odd screens popped up before Windows loaded. So, I think it might have to do with my BIOS and I do not think the log caught it. Is there a way log bios screens? Or do I need to go low-tech and record it with my digicam? Thanks |
| Vista Home Premium (32), XP Pro (32), Vista Ultimate (64) | Re: Backing Up Problem if it is a bios problem, then you're right, it wouldn't have been logged by windows. to my knowledge, there's not a way to log the bios screens so you might have to use the camera if you think it's something in bios that's doing it. I doubt that your bios is affecting the shadow copy service, however. most likely one of the files that the service needs to run is corrupted due to a bad write to your hard drive or something of that nature. if chkdsk came up with nothing, then there's the possibility that part of your OS was written to a bad sector on the hard drive, thus it may be a physical flaw in the drive. If that's the case, you'll probably have to do a low-level format and start over to fix it. But I've found some possible answers to the errors you've found. Assuming they're linked to your problem (which is a pretty good assumption), here are the solutions: Solution to Event ID:8193 EventID.Net Solution to Event ID:13 EventID.Net ^that one seems pretty useless unfortunately I couldn't find a specific solution anywhere for event id 34 It is also possible that you have a damaged COM+ catalog. to fix that go here: How to clean up a damaged COM+ catalog but be careful in your registry! Hope one or more of these will help. |
| Problem backing up messages in Windows Live Mail | Windows Live | |||
| Backing up to new PC | Vista General | |||
| Backing Up Problem | Vista performance & maintenance | |||
| Problem backing up on a mapped drive using Backup and Restore Cent | Vista account administration | |||
| Backing up problem | Vista General | |||
