| | ACPI\PNPB02F Unknown device issue solved!!!! I have spent way too much time trying to solve the very annoying ACPI\PNPB02F Unknown device issue which asks me to scan the computer for a solution everytime I boot. And this discovery process seems also to have disabled some startup programs (a pdf "printer driver" and the antivirus tray application). Disabling it or deleting it is not an option (I have tried numerous ways of doing that) as it stops my Pocket PC USB cradle from working for some reason. Carlos, in another thread, suggested that it wasn't a sound card issue, as others have suggested, but that it is a motherboard issue. He suggested disabling the midi and game ports in the BIOS setup. This solved the issue! Based upon Carlos's tip I went to the Bios setup and disabled the Motherboard's built-in Game Port (which I never use) and VOILA the issue was solved and everythign works now!!!!! (The midi port was already disabled.) Based upon other suggestions I had already tried installing a game port driver but found that on the built-in list of devices that can be installed manually when New Hardware isn't able to install something, the category that included Game Ports actually didn't have a Game Port driver available! They apparently forgot to include a Game Port driver for ACPI\PNPB02F ! Should be pretty easy to fix on the next update. |
| Unknown Device on Microsoft ACPI Compliant Embedded Controller?!?! | Drivers | |||
| Unknown Device (Related to ACPI) | Drivers | |||
| ACPI\PNPB02F Unknown device issue solution | Vista hardware & devices | |||
| ACPI\PNPB02F problem with vista beta 2 | Vista General | |||
| ACPI\PNPB02F Unknown device | Vista General | |||
