| | will two tv tuner cards normally crash? does anyone have the experience to install two tv tuner cards from different companies into a computer running Vista? will they normally/ definitely crash with each other? many thanks for any responses!! markiloon |
| | Re: will two tv tuner cards normally crash? I have seen no reports of tuner cards from different vendors clashing. and I have seen many reports of users using pairs of analog tuner and pairs of digital tuner cards from different vendors. "markiloon" <markiloon@xxxxxx> wrote in message news:1190903182.239501.15950@xxxxxx Quote: > does anyone have the experience to install two tv tuner cards from > different companies into a computer running Vista? will they normally/ > definitely crash with each other? > > many thanks for any responses!! > markiloon > |
| | Re: will two tv tuner cards normally crash? markiloon wrote: Quote: > does anyone have the experience to install two tv tuner cards from > different companies into a computer running Vista? will they normally/ > definitely crash with each other? > > many thanks for any responses!! > markiloon > problem but newer cards should not. Even if it did cause a problem you might be able to change such things as IRQ etc in the BIOS but if we're talking Vista there would probably not be any drivers for a card that age anyway. I'd suggest you use something like Acronis True Image and make a "Full" backup when trying anything like this just to be sure you can recover. |
| | Re: will two tv tuner cards normally crash? In theory it should work. But you'd be better off using two of the same. If one has Hardware decoding and the other uses Software it may cause a problem. I use 2 ATI 550's with no problems in BeyondTV. Don't try Media Center. It's well worth the money for BTV I can stream 2 channels at a time over my network. Or watch the recorded stuff on any pc on the network. Robert "markiloon" <markiloon@xxxxxx> wrote in message news:1190903182.239501.15950@xxxxxx Quote: > does anyone have the experience to install two tv tuner cards from > different companies into a computer running Vista? will they normally/ > definitely crash with each other? > > many thanks for any responses!! > markiloon > |
| | Re: will two tv tuner cards normally crash? On Sep 27, 10:26 pm, markiloon <markil...@xxxxxx> wrote: Quote: > does anyone have the experience to install two tv tuner cards from > different companies into a computer running Vista? will they normally/ > definitely crash with each other? > > many thanks for any responses!! > markiloon yesterday i wanted to add a Winfast PVR3000 Deluxe with hardware MPEG2 compression. i was about to buy it. but four salesmen from four different computer shops told me two tv tuner cards from different vendors would VERY PROBABLY clash with each other. does anyone else other than Robert Martin who also has experiences that two tv tuner cards do indeed not clash with each other? again, thanks a lot for any responses!! markiloon. |
| Which HDTV tuner cards are best for my 64 bit computer? | Graphic cards | |||
| will two tv tuner cards normally crash? | Vista hardware & devices | |||
| do any TV tuner cards actually work in Vista? | Vista music pictures video | |||
| # of tuner cards vista will support | Vista installation & setup | |||
| TV Tuner Cards | Vista hardware & devices | |||
