Vista - system restore
Old 10-20-2007   #11 (permalink)
Bert Kinney
Re: system restore
Sorry about that, here you go Andy.
How to use System Restore in Windows Vista:
http://bertk.mvps.org/html/restoresysv.html
Regards,
Bert Kinney MS-MVP Shell/User
Member: http://dts-l.org
andy wrote:
Quote:
> Bert- I have WIN VISTA HOME PREMIUM not XP
> Send another link..please.
> "Bert Kinney" wrote:
Quote:
>> Here are the instructions on how to run System Restore. The worst that will
>> happen is it will fail to restore.
>> All About System Restore in WinXP
>> Here are some troubleshooting steps to take when System Restore fails to
>> restore:
>> http://bertk.mvps.org/html/srfail.html
>> Regards,
>> andy wrote:
Quote:
>>> BERT- it was POGO.COM off the internet
>>> What if the system restore fails like it has done with other people...?
>>> Please advise before I screw up my computer...
>>> Thanks
>>> Andy
>>>> What was the name of the game?
>>>> Now use System Restore and restore the computer to just before the game was
>>>> installed.
>>>> Regards,
>>>> andy wrote:
>>>>> Bert-
>>>>> I did the UNINSTALL from the add/remove section under the control
>>>>> panel..While it DID take it out of the Add/remove area , it is STILL on the
>>>>> desktop and still works when I click on it.
>>>>> This is from pogo.com and I cannot get rid of it...I was told to do a system
>>>>> restore by someone on this site but I do not want to screw up my computer
>>>>> anymore than it already is..I get a blinking screen that goes BLACK, then
>>>>> desktop, then Black again, then desk finaly loads.
>>>>> I have no idea how to fix this............
>>>>> Any help will be greatly appreciated. and by the way, my clock is set
>>>>> correctly..If THAT means anything?
>>>>> Andy
>>>>>> Hi,
>>>>>> System Restore was never intended to be used to uninstall applications, and
>>>>>> should not be used to do so.
>>>>>> Undo the restore and uninstall the applications via Programs and Features in
>>>>>> Control Panel.
>>>>>> Regards,
>>>>>> maeve wrote:
>>>>>>> Hi, I have used system restore and because I removed programs before I
>>>>>>> did this the programs they still show as being installed. How do I
>>>>>>> remove them from my program uninstall? Thanks
Old 10-20-2007   #12 (permalink)
Bert Kinney
Re: system restore
I would not recommend using McAfee at all.
Here are two much better alternatives.
NOD32 Antivirus Software for Windows from ESET
http://www.eset.com/products/windows.php
Free antivirus - avast! 4 Home Edition Download
http://www.avast.com/eng/download-avast-home.html
Regards,
andy wrote:
Quote:
> Bert- I am ALSO running McAfee Security Suite- as it is free with my comcast
> membership...How do I troubleshoot for MCAfee and NOT Norton.
> Help!!!
>> restore:
>> Regards,
>>> Thanks
>>> Andy
>>>> installed.
>>>> Regards,
>>>> andy wrote:
>>>>> Bert-
>>>>> Andy
>>>>>> Hi,
>>>>>> Control Panel.
>>>>>> Regards,
Old 10-20-2007   #13 (permalink)
andy
Re: system restore
Bert-
Office 2007 said to do EXACTLY what I did..nothing is working..
> Regards,
> > Help!!!
> >> restore:
> >> Regards,
> >>> Thanks
> >>> Andy
> >>>> installed.
> >>>> Regards,
> >>>> andy wrote:
> >>>>> Bert-
> >>>>> Andy
> >>>>>> Hi,
> >>>>>> Control Panel.
> >>>>>> Regards,
System Restore Task - Change Automatic Restore Point Schedule Tutorials
System Restore error (create restore point), event ID: 8193 Vista General
System Restore: do restore points persist after a restore? Vista General
System restore hasn't held a restore point since I installed Vista Vista General
system restore not creating system restore everyday Vista General
