Vista Tutorial - system restore
Old 09-27-2007   #1 (permalink)
maeve
Guest
system restore
Hi, I have used system restore and because I removed programs before I did
this the programs they still show as being installed. How do I remove them
from my program uninstall? Thanks
Old 09-28-2007   #2 (permalink)
Bert Kinney
Guest
Re: system restore
System Restore was never intended to be used to uninstall applications, and
should not be used to do so.
Undo the restore and uninstall the applications via Programs and Features in
Control Panel.
Regards,
Bert Kinney MS-MVP Shell/User
http://bertk.mvps.org
Member: http://dts-l.org
maeve wrote:
> did this the programs they still show as being installed. How do I
> remove them from my program uninstall? Thanks
Old 09-28-2007   #3 (permalink)
Frank
Guest
Re: system restore
Tiberius wrote:
Quote:
> It seems that vista users & MVPs have a reading comprehension problem.
> He was not trying to uninstall programs with system restore. He used system
> restore to fix a unrelated problem .
> However after the restore point automatic snapshot he had uninstalled
> programs. When reverted back to the time of the restore point the add remove
> list had them listed, while most of the programs were indeed missing most of
> the files since system restore does not restore all files, thus he could not
> uninstall them properly.
> Do you understand this?
Huh! Do you?
Frank
Old 10-19-2007   #4 (permalink)
andy
Guest
Re: system restore
Bert-
I did the UNINSTALL from the add/remove section under the control
panel..While it DID take it out of the Add/remove area , it is STILL on the
desktop and still works when I click on it.
This is from pogo.com and I cannot get rid of it...I was told to do a system
restore by someone on this site but I do not want to screw up my computer
anymore than it already is..I get a blinking screen that goes BLACK, then
desktop, then Black again, then desk finaly loads.
I have no idea how to fix this............
Any help will be greatly appreciated. and by the way, my clock is set
correctly..If THAT means anything?
Andy
"Bert Kinney" wrote:
Quote:
> Hi,
> Control Panel.
> Regards,
Old 10-19-2007   #5 (permalink)
Administrator
Re: system restore
Quote  Quote: Originally Posted by maeve View Post
Hi Maeve,
This tutorial will show you how to remove a uninstall entry from Programs and Features.
Programs and Features - Remove Uninstall Entry
Old 10-19-2007   #6 (permalink)
Bert Kinney
Guest
Re: system restore
What was the name of the game?
Now use System Restore and restore the computer to just before the game was
installed.
Regards,
andy wrote:
Quote:
> Bert-
> Andy
Quote:
>> Hi,
>> Control Panel.
>> Regards,
Old 10-19-2007   #7 (permalink)
andy
Guest
Re: system restore
BERT- it was POGO.COM off the internet
What if the system restore fails like it has done with other people...?
Please advise before I screw up my computer...
Thanks
Andy
> installed.
> Regards,
> andy wrote:
Quote:
> > Bert-
> > Andy
Quote:
> >> Hi,
> >> Control Panel.
> >> Regards,
Old 10-19-2007   #8 (permalink)
Bert Kinney
Guest
Re: system restore
Here are the instructions on how to run System Restore. The worst that will
happen is it will fail to restore.
All About System Restore in WinXP
http://bertk.mvps.org/
Here are some troubleshooting steps to take when System Restore fails to
restore:
http://bertk.mvps.org/html/srfail.html
Regards,
> Thanks
> Andy
>> installed.
>> Regards,
>> andy wrote:
Quote:
>>> Bert-
>>> Andy
>>>> Hi,
>>>> Control Panel.
>>>> Regards,
Old 10-19-2007   #9 (permalink)
andy
Guest
Re: system restore
Bert- I have WIN VISTA HOME PREMIUM not XP
Send another link..please.
> restore:
> Regards,
> > Thanks
> > Andy
> >> installed.
> >> Regards,
> >> andy wrote:
> >>> Bert-
> >>> Andy
> >>>> Hi,
> >>>> Control Panel.
> >>>> Regards,
Old 10-19-2007   #10 (permalink)
andy
Guest
Re: system restore
Bert- I am ALSO running McAfee Security Suite- as it is free with my comcast
membership...How do I troubleshoot for MCAfee and NOT Norton.
Help!!!
> restore:
> Regards,
> > Thanks
> > Andy
> >> installed.
> >> Regards,
> >> andy wrote:
> >>> Bert-
> >>> Andy
> >>>> Hi,
> >>>> Control Panel.
> >>>> Regards,
System Restore Task - Change Automatic Restore Point Schedule Tutorials
System Restore error (create restore point), event ID: 8193 Vista General
System Restore: do restore points persist after a restore? Vista General
System restore hasn't held a restore point since I installed Vista Vista General
system restore not creating system restore everyday Vista General
