Vista - Media Center does not recognize tuner
Old 09-28-2007   #1 (permalink)
Canvecchio
I have a Plextor ConvertX PX-TV402U Connected to a Dell Dimension 9200.
This tuner is listed as working properly in Device Manager, and it works
fine with Sage TV or Intervideo Home Theater, but Vista Home Premium Media
Center does not detect it and reports I have no tuner.
Is this a known problem and is there a fix.
Old 09-28-2007   #2 (permalink)
Synapse Syndrome
Re: Media Center does not recognize tuner
"Canvecchio" <Canvecchio@xxxxxx> wrote in message
news:3AF9298E-0A62-4908-8603-C6703DB4ADE5@xxxxxx
That looks like a nice bit of hardware, but it has no BDA drivers for it to
work with Media Centre. Look on the right, under the links:
http://www.plextor.com/ENGLISH/products/TV402U.htm
"Note: ConvertX products are not compatible with Windows Media Center
Edition or Windows Vista OS"
ss.
Old 09-28-2007   #3 (permalink)
Vista Ultimate 64-bit
Don't feel bad. My Terratec Cinergy HT PCI is supposed to be 100% Media Center compatible, but Media Center can't find it with both hands, BDA driver 'n all.
Old 09-28-2007   #4 (permalink)
Synapse Syndrome
"John_T" <John_T.2xn8bv@xxxxxx-mx.forums.net> wrote in message
news:John_T.2xn8bv@xxxxxx-mx.forums.net...
> driver 'n all.
Quote:
> *vista ultimate 64-bit : c2 q6700 : ga-p35-dq6 : 4gb ram : 8800gtx : 2tb
> hdd : 720w psu : 2x eizo cg241w*
That might be because there are no 64-bit BDA drivers for it?
ss.
Old 09-28-2007   #5 (permalink)
Synapse Syndrome
Oh by the way, with a powerful system like that, I bet you wished you waited
for the X38 chipset, which has just come out. I won't be replacing my 975X
based system for another couple of years though.
ss.
Old 09-29-2007   #6 (permalink)
No, I studied up on the X38 before deciding because I could have gotten the GA-X38-DQ6. According to a number of test reports I read, the difference in performance is tiny. My next move will be to DDR3.
Old 09-29-2007   #7 (permalink)
Synapse Syndrome
"John_T" <John_T.2xnxb8@xxxxxx-mx.forums.net> wrote in message
news:John_T.2xnxb8@xxxxxx-mx.forums.net...
Hmmn, I thought you might know about hardware..
ss.
Old 09-29-2007   #8 (permalink)
No, I have the 64-bit BDA drivers for the Terratec HT PCI, and it works fine with the Terratec software, but Media Center does a scan and comes up with zero channels, while the Terratec program gives me 60 TV channels and 50 radio stations. Go figure...
Old 11-04-2007   #9 (permalink)
SeniorAsTech
I'm using the same TV-Tuner Card (Cinergy HT PCI on Vista 64Bit) and my
problem is that the VistaMediaCenter only is searching for DVB-T Channels,
not for analog... I have no idea where to config MC for this, any ideas?
Thx,
SAT
> John_T
Old 11-04-2007   #10 (permalink)
Dominic Payer
If the card does not have hardware mpeg2 encoding Windows Media Center will
not work for analog channels.
"SeniorAsTech" <SeniorAsTech@xxxxxx> wrote in message
news:54B865A5-F5CE-4619-89CF-320809BCC8F6@xxxxxx
Quote:
> Hi,
> Thx,
> SAT
>> John_T
Vista Media center does not recognize my Asus 7134TV tuner card Vista hardware & devices
media center is not able to recognize dvd in player Media Center
tv tuner with media center Vista General
tv tuner/media center setup help Vista installation & setup
Media Center will not recognize tv tuner Vista music pictures video
