Vista - Vista upgrade certain web links will not open
Old 10-01-2007   #1 (permalink)
keith
Since upgrading Windows XP to Vista certain web links, specifically the free
Mcafee anti virus suite offered through Comcast, will not open. I know the
site is fine as I can access it through my preinstalled Vista desktop PC
using the same gateway. Gateway, McAfee , Comcast and Microsoft have been no
help...Any suggestions?
keith
Old 10-01-2007   #2 (permalink)
Rick Rogers
Re: Vista upgrade certain web links will not open
Close any open instances of Internet Explorer.
Go to the Control Panel/Internet Options/General tab, under browsing history
click on 'delete'.
Delete Temporary Internet Files and Cookies. Close this dialog when
complete.
Click start, type CMD. Right click the entry in the start menu, choose 'run
as administrator'.
From the prompt, run "ipconfig /flushdns" (without the quotes). When
complete, exit the command prompt.
Retry the sites.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"keith" <keith@xxxxxx> wrote in message
news:CE7EE809-3F8C-4666-83B3-29B08A769095@xxxxxx
> free
> no
> keith
Can't open new links in IE Vista General
New links open minimised in IE7 using Vista. Vista General
IE 7 in Windows Vista won't open links Vista General
Think I found a bug on some links (lnk), vista open them with no user intervention! Vista security
Unable to open links in Outlook 2007 on Vista 5384 Vista General
