| | Explorer.exe is not running once logged in? Hi there, Heres my specs: AMD ATHLON X2 64 4600+ 2Gb DDR2 800mhz PNY RAM Gigabyte S4 SLi Mobo Radeon X1950 pro gfx 500gb Maxtor SATA drive (Vista Ultimate loaded on , 1 partition) Primary boot! 80gb Seagate IDE drive (Vista Corportate loaded on but never used apart from music etc.) It just came out of the blue, possibly after an update on my PC or something , but when I logged in all I could see was a window opened up in my User folder. So I navigated from there to my Windows folder and manually clicked and ran explorer.exe which then caused everything I should expect on the desktop to appear e.g. ( Taskbar, Sidebar, Icons etc.). I checked the file to see if it was corrupted and it is not and it is obviously not deleted either or else I wouldnt be talking to you right now lol. I checked msconfig.exe to see if it was blocked but it is not but i cant find it in there. Please help me , ok I know its not critical but it is a real nuisance having to navigate from My Documents to Windows every time I logon just so I can get my desktop up and running. Thanks |
| | Re: Explorer.exe is not running once logged in? download autoruns from micrsoft (free) http://www.microsoft.com/technet/sys.../AutoRuns.mspx see if you have this entry: SEE SCREENSHOT (red circle) http://img209.imageshack.us/img209/9208/sshot2qy3.jpg tell us what you see "Spartan117.Halo" <Spartan117.Halo@xxxxxx> wrote in message news:7131625C-1BA8-4648-B3F3-72C1B05BA24E@xxxxxx Quote: > Hi there, > > Heres my specs: > > AMD ATHLON X2 64 4600+ > 2Gb DDR2 800mhz PNY RAM > Gigabyte S4 SLi Mobo > Radeon X1950 pro gfx > 500gb Maxtor SATA drive (Vista Ultimate loaded on , 1 partition) Primary > boot! > 80gb Seagate IDE drive (Vista Corportate loaded on but never used apart > from > music etc.) > > It just came out of the blue, possibly after an update on my PC or > something > , but when I logged in all I could see was a window opened up in my User > folder. So I navigated from there to my Windows folder and manually > clicked > and ran explorer.exe which then caused everything I should expect on the > desktop to appear e.g. ( Taskbar, Sidebar, Icons etc.). > I checked the file to see if it was corrupted and it is not and it is > obviously not deleted either or else I wouldnt be talking to you right now > lol. > I checked msconfig.exe to see if it was blocked but it is not but i cant > find it in there. > > Please help me , ok I know its not critical but it is a real nuisance > having > to navigate from My Documents to Windows every time I logon just so I can > get > my desktop up and running. > > Thanks |
| Virtual PC 2007 - Kept running while logged off? | Software | |||
| Explorer.exe Running at 100% | Vista General | |||
| explorer not running | .NET General | |||
| internet explorer stops running | Vista General | |||
| Explorer.exe Not running correctly (Crashing) | Vista General | |||
