I am left handed on using mouse. But Windows Vista has no memory about my
mouse settings --- everytime after reboot, it goes back to right-handed mouse
with default sensitivity setting.
Hi Fire Phoenix,
Are you using the same method in this tutorial?
Mouse Button
If you are, you might check to see is there is a newer version for your mouse drivers.
> Are you using the same method in this tutorial?I have two mice --- one is Logitech wireless mouse and second is Dell
> Mouse Button
> your mouse drivers.
> Shawn
optical mouse. I've updated drivers, including using Windows update and also
downloading the newest driver from Logitech. I also tried to plug in a mouse
at a time. None of these helps.
I tried to uninstall Logitech's SetPoint software (driver is bundled). It
had no effect on fixing the problem. I didn't try to uninstall the other one,
because Dell's optical mouse is using the driver called "HID-compliant
mouse", which probably came with Windows Vista.
> You may have a conflict between the two mice drivers being installed
> together. Try unplugging one of them and uninstalling the driver for it
> in Device Manager so you just have one. Test it for each one to see
> which one is may be causing the problem.
> Shawn
Fire Phoenix,
I found this thread to be very interesting for your problem. It seems you are not the only one having problems with Logitech and the Setpoint drivers. According to this thread you will need to look in MSCONFIG and deselect all remaining Logitech items. (See post 7)
TechArena Community - View Single Post - Mouse settings reset to default every time
This tutorial will show you how to use MSCONFIG if you need it. Scroll down a bit and look at method two.
Startup Programs - Enable or Disable
| Similar Threads | ||||
| Setting the System Up for Permanent Screen Visibility | Roger Stenson | Vista installation & setup | 2 | 13 Mar 2010 |
| Permanent CC on all emails | automatic cc | Vista mail | 0 | 22 Jul 2009 |
| Re: Vista & IE7 Protected Mode Setting not Permanent | PA Bear [MS MVP] | Vista security | 0 | 28 Apr 2008 |
| Mouse setting problem | dougpsy | Vista hardware & devices | 2 | 23 Jun 2007 |
| Unable to access mouse setting in control panel. | edearl | Vista hardware & devices | 0 | 19 Feb 2007 |
