Vista Tutorial - Program Startup Problem
Old 10-03-2007   #1 (permalink)
jimbo
Guest
Can someone tell me how to turn off the Popup I keep getting, that
states..(Vista has stopped some startup programs) Everything is running that
I want running upon startup.
Thanks
Old 10-03-2007   #2 (permalink)
Administrator
Re: Program Startup Problem
Quote  Quote: Originally Posted by jimbo View Post
Thanks
Hi Jimbo,
Take a look at Method two (Step 9) in this tutorial. It will show you how to get rid of it. Just scroll down a bit.
System Restore - disk space
Old 10-03-2007   #3 (permalink)
jimbo
Guest
Sorry Shawn I could not get anything out of that tutorial for system
restore, is there any other instructions you could give me.
"brink" <brink.2xwfk0@xxxxxx-mx.forums.net> wrote in message
news:brink.2xwfk0@xxxxxx-mx.forums.net...
Quote:
>> that
>> Thanks
> Hi Jimbo,
> Shawn
> brink
> *There are no dumb questions, just the people that do not ask them.*
> WWW.VISTAX64.COM (\"HTTP://WWW.VISTAX64.COM\")
> *Please post feedback to help others.*
Old 10-03-2007   #4 (permalink)
Administrator
Sorry Jimbo,
Had the wrong one posted there. See Method Two (Step 9) in this tutorial.
Startup Programs - Enable or Disable
Sorry,
Program startup problem General Discussion
Solved Running program in startup as administrator without any problem Software
Getting program to run at startup Software
startup program Vista General
Automatically start a program at startup problem Vista hardware & devices
