| | WinHlp32.exe installation problem vista business hi! i hope that someone can help me. i need the winhlp32.exe on my windows vista business pc to open 32-bit-help files. i downloaded the file Windows6.0-KB917607-x86.msu and started the installation. but then, windows vista said "the update is not available for your system". but it is the right one. is there a trick to install the package? thanks for every help. stefan info: microsoft kb917607 |
| | Re: WinHlp32.exe installation problem vista business "roadrunner84" <se@xxxxxx(donotspam)> wrote in message news 518C454-133E-4090-A6C7-ACD8F3ED2494@xxxxxxQuote: > hi! i hope that someone can help me. i need the winhlp32.exe on my > windows vista business pc to open 32-bit-help files. i downloaded the > file Windows6.0-KB917607-x86.msu and started the installation. but > then, windows vista said "the update is not available for your > system". but it is the right one. is there a trick to install the > package? thanks for every help. stefan info: microsoft kb917607 you have. ss. |
| | Re: WinHlp32.exe installation problem vista business i have the 32-bit version and downloaded the 32-bit installation file. there is a 64-bit installation file to.... "Synapse Syndrome" wrote: Quote: > "roadrunner84" <se@xxxxxx(donotspam)> wrote in message > news 518C454-133E-4090-A6C7-ACD8F3ED2494@xxxxxxQuote: > > hi! i hope that someone can help me. i need the winhlp32.exe on my > > windows vista business pc to open 32-bit-help files. i downloaded the > > file Windows6.0-KB917607-x86.msu and started the installation. but > > then, windows vista said "the update is not available for your > > system". but it is the right one. is there a trick to install the > > package? thanks for every help. stefan info: microsoft kb917607 > Are you sure you are not running Vista 64-bit? You never said what version > you have. > > ss. > > > |
| | Re: WinHlp32.exe installation problem vista business Hello roadrunner84, I get the error message also, but the reason is that it is already installed. Did you check the installed update list? Best regards Meinolf Weber Disclaimer: This posting is provided "AS IS" with no warranties, and confers no rights. Quote: > hi! i hope that someone can help me. i need the winhlp32.exe on my > windows vista business pc to open 32-bit-help files. i downloaded the > file Windows6.0-KB917607-x86.msu and started the installation. but > then, windows vista said "the update is not available for your > system". but it is the right one. is there a trick to install the > package? thanks for every help. stefan info: microsoft kb917607 > |
| | Re: WinHlp32.exe installation problem vista business hey, thanks for the help!! i saw that the update was already installed on 16.5.07.... so now i found out that the problem is when i open programs (help files) from our server. the local help files work! thanks! "Meinolf Weber" wrote: Quote: > Hello roadrunner84, > > I get the error message also, but the reason is that it is already installed. > Did you check the installed update list? > > Best regards > > Meinolf Weber > Disclaimer: This posting is provided "AS IS" with no warranties, and confers > no rights. > Quote: > > hi! i hope that someone can help me. i need the winhlp32.exe on my > > windows vista business pc to open 32-bit-help files. i downloaded the > > file Windows6.0-KB917607-x86.msu and started the installation. but > > then, windows vista said "the update is not available for your > > system". but it is the right one. is there a trick to install the > > package? thanks for every help. stefan info: microsoft kb917607 > > > > |
| | #6 (permalink) |
| | Re: WinHlp32.exe installation problem vista business Hello roadrunner84, Is it server 2003 with SP2? Even this link states SBS it works also in normal 2003: http://blogs.technet.com/sbs/archive...ce-pack-2.aspx Best regards Meinolf Weber Disclaimer: This posting is provided "AS IS" with no warranties, and confers no rights. Quote: > hey, thanks for the help!! i saw that the update was already installed > on 16.5.07.... so now i found out that the problem is when i open > programs (help files) from our server. the local help files work! > thanks! > > "Meinolf Weber" wrote: > Quote: >> Hello roadrunner84, >> >> I get the error message also, but the reason is that it is already >> installed. Did you check the installed update list? >> >> Best regards >> >> Meinolf Weber >> Disclaimer: This posting is provided "AS IS" with no warranties, and >> confers >> no rights. Quote: >>> hi! i hope that someone can help me. i need the winhlp32.exe on my >>> windows vista business pc to open 32-bit-help files. i downloaded >>> the file Windows6.0-KB917607-x86.msu and started the installation. >>> but then, windows vista said "the update is not available for your >>> system". but it is the right one. is there a trick to install the >>> package? thanks for every help. stefan info: microsoft kb917607 >>> |
| | #7 (permalink) |
| | Re: WinHlp32.exe installation problem vista business No, it is an Windows 2003 R2 SP1 Server in english. The help and support service isn't runnig. So, should the service run? I only need to open help-files from the vista machine over the network share.... "Meinolf Weber" wrote: Quote: > Hello roadrunner84, > > Is it server 2003 with SP2? Even this link states SBS it works also in normal > 2003: > > http://blogs.technet.com/sbs/archive...ce-pack-2.aspx > > > Best regards > > Meinolf Weber > Disclaimer: This posting is provided "AS IS" with no warranties, and confers > no rights. > Quote: > > hey, thanks for the help!! i saw that the update was already installed > > on 16.5.07.... so now i found out that the problem is when i open > > programs (help files) from our server. the local help files work! > > thanks! > > > > "Meinolf Weber" wrote: > > Quote: > >> Hello roadrunner84, > >> > >> I get the error message also, but the reason is that it is already > >> installed. Did you check the installed update list? > >> > >> Best regards > >> > >> Meinolf Weber > >> Disclaimer: This posting is provided "AS IS" with no warranties, and > >> confers > >> no rights. > >>> hi! i hope that someone can help me. i need the winhlp32.exe on my > >>> windows vista business pc to open 32-bit-help files. i downloaded > >>> the file Windows6.0-KB917607-x86.msu and started the installation. > >>> but then, windows vista said "the update is not available for your > >>> system". but it is the right one. is there a trick to install the > >>> package? thanks for every help. stefan info: microsoft kb917607 > >>> > > |
| | #8 (permalink) |
| | Re: WinHlp32.exe installation problem vista business Hello roadrunner84, If you don't need it, no. I thought it does not work at all. Best regards Meinolf Weber Disclaimer: This posting is provided "AS IS" with no warranties, and confers no rights. Quote: > No, it is an Windows 2003 R2 SP1 Server in english. The help and > support service isn't runnig. So, should the service run? I only need > to open help-files from the vista machine over the network share.... > > "Meinolf Weber" wrote: > Quote: >> Hello roadrunner84, >> >> Is it server 2003 with SP2? Even this link states SBS it works also >> in normal 2003: >> >> http://blogs.technet.com/sbs/archive...d-support-serv >> ice-missing-after-installing-windows-2003-service-pack-2.aspx >> >> Best regards >> >> Meinolf Weber >> Disclaimer: This posting is provided "AS IS" with no warranties, and >> confers >> no rights. Quote: >>> hey, thanks for the help!! i saw that the update was already >>> installed on 16.5.07.... so now i found out that the problem is when >>> i open programs (help files) from our server. the local help files >>> work! thanks! >>> >>> "Meinolf Weber" wrote: >>> >>>> Hello roadrunner84, >>>> >>>> I get the error message also, but the reason is that it is already >>>> installed. Did you check the installed update list? >>>> >>>> Best regards >>>> >>>> Meinolf Weber >>>> Disclaimer: This posting is provided "AS IS" with no warranties, >>>> and >>>> confers >>>> no rights. >>>>> hi! i hope that someone can help me. i need the winhlp32.exe on my >>>>> windows vista business pc to open 32-bit-help files. i downloaded >>>>> the file Windows6.0-KB917607-x86.msu and started the installation. >>>>> but then, windows vista said "the update is not available for your >>>>> system". but it is the right one. is there a trick to install the >>>>> package? thanks for every help. stefan info: microsoft kb917607 >>>>> |
| Windows Vista Business 64 bit installation | Vista installation & setup | |||
| Re-installation of Windows Vista Business | Vista installation & setup | |||
| Windows Vista Business Installation | Vista installation & setup | |||
| Vista Business installation woes | Vista installation & setup | |||
| Re: Clean installation using Vista Business Upgrade | Vista installation & setup | |||
