| | vista 64 bit upgrade problems I am on a Latitude D830 with 4 gig ram, t7700 dual core processor and 160 gig hdd. my system is vista business 32 bit . i bought a 64 bit retail upgrade but it say "Setup can not ru on this version of the Operating System. To install Windows please try booting from the install media. However, when i do this it says i cannot use my key unless i do upgrade from within the os. I have seen similar problems with no solutions on several blogs. Can anyone help me?? Also, Ms. Office Pro Disappeared off my hdd the first time i attempted to run the upgrade install. Thanks in advance for any help Alan |
| | Re: vista 64 bit upgrade problems There is no upgrade path from a 32-bit version of Vista to the 64-bit version of Vista. You'll need to purchase a "full version" of the 64-bit version and perform a "clean install". The 64-bit upgrade version is only valid if you already are running a 64-bit version of Windows XP. Installation choices for 64-bit consumer versions of Windows Vista http://support.microsoft.com/kb/932795 "Windows XP Professional x64 users can purchase an upgrade license for the 64-bit version of Windows Vista. However, they must perform a clean installation of the operating system." -- Carey Frisch Microsoft MVP Windows Shell/User --------------------------------------------------------------- "Alan" wrote: I am on a Latitude D830 with 4 gig ram, t7700 dual core processor and 160 gig hdd. my system is vista business 32 bit . i bought a 64 bit retail upgrade but it say "Setup can not ru on this version of the Operating System. To install Windows please try booting from the install media. However, when i do this it says i cannot use my key unless i do upgrade from within the os. I have seen similar problems with no solutions on several blogs. Can anyone help me?? Also, Ms. Office Pro Disappeared off my hdd the first time i attempted to run the upgrade install. Thanks in advance for any help Alan |
| | RE: vista 64 bit upgrade problems read and follow these instructions carefully - http://blogs.zdnet.com/Bott/?p=196 you will need to do a clean install but you should have everything you need "Alan" wrote: Quote: > I am on a Latitude D830 with 4 gig ram, t7700 dual core processor and > 160 gig hdd. my system is vista business 32 bit . i bought a 64 bit > retail upgrade but it say > "Setup can not ru on this version of the Operating System. To install > Windows please try booting from the install media. However, when i do > this it says i cannot use my key unless i do upgrade from within the > os. I have seen similar problems with no solutions on several blogs. > Can anyone help me?? Also, Ms. Office Pro Disappeared off my hdd the > first time i attempted to run the upgrade install. > Thanks in advance for any help > > > Alan > > |
| | Re: vista 64 bit upgrade problems Carey Frisch [MVP] wrote: Quote: > There is no upgrade path from a 32-bit version of Vista > to the 64-bit version of Vista. You'll need to purchase > a "full version" of the 64-bit version and perform a > "clean install". The 64-bit upgrade version is only valid > if you already are running a 64-bit version of Windows XP. > > Installation choices for 64-bit consumer versions of Windows Vista > http://support.microsoft.com/kb/932795 > > "Windows XP Professional x64 users can purchase an upgrade license for the 64-bit version of Windows Vista. However, they must > perform a clean installation of the operating system." > The 64 bit upgrade version merely checks that you have a valid OS installed. The installation will proceed as a "clean" install. |
| | Re: vista 64 bit upgrade problems Having a 32-bit installation of Vista does not qualify for the upgrade version of the 64-bit version. -- Carey Frisch Microsoft MVP Windows Shell/User --------------------------------------------------------------- "cvp" <goaway@xxxxxx> wrote in message news:OOswQs4BIHA.3916@xxxxxx Carey Frisch [MVP] wrote: Quote: > There is no upgrade path from a 32-bit version of Vista > to the 64-bit version of Vista. You'll need to purchase > a "full version" of the 64-bit version and perform a > "clean install". The 64-bit upgrade version is only valid > if you already are running a 64-bit version of Windows XP. > > Installation choices for 64-bit consumer versions of Windows Vista > http://support.microsoft.com/kb/932795 > > "Windows XP Professional x64 users can purchase an upgrade license for the 64-bit version of Windows Vista. However, they must > perform a clean installation of the operating system." > The 64 bit upgrade version merely checks that you have a valid OS installed. The installation will proceed as a "clean" install. |
| | #6 (permalink) |
| | Re: vista 64 bit upgrade problems Carey Frisch [MVP] wrote: Quote: > Having a 32-bit installation of Vista does not > qualify for the upgrade version of the 64-bit version. > Wrong again! Since you gave the link, which part of "If you purchase a 64-bit upgrade version of Windows Vista with the intention of installing on a computer that is running a 32-bit operating system, you must install Windows Vista by starting the computer from the 64-bit Vista installation DVD." and "The following installed operating systems are eligible for a Windows Vista upgrade installation: ... • Windows Vista Home Basic (32-bit and 64-bit) • Windows Vista Home Premium (32-bit and 64-bit) • Windows Vista Business (32-bit and 64-bit) • Windows Vista Ultimate (32-bit and 64-bit)" do you not understand? |
| | #7 (permalink) |
| | Re: vista 64 bit upgrade problems You are wrong, Carey. You just have to upgrade to the equivalent of Pro or higher. :-) The upgrade must be done as a clean install with the upgrade version. "Carey Frisch [MVP]" <cnfrisch@xxxxxx> wrote in message news 5F1D2A0-A01F-4E8A-9D5D-AFC2861AC9D9@xxxxxxQuote: > Having a 32-bit installation of Vista does not > qualify for the upgrade version of the 64-bit version. > > -- > Carey Frisch > Microsoft MVP > Windows Shell/User > > --------------------------------------------------------------- > > "cvp" <goaway@xxxxxx> wrote in message > news:OOswQs4BIHA.3916@xxxxxx > Carey Frisch [MVP] wrote: Quote: >> There is no upgrade path from a 32-bit version of Vista >> to the 64-bit version of Vista. You'll need to purchase >> a "full version" of the 64-bit version and perform a >> "clean install". The 64-bit upgrade version is only valid >> if you already are running a 64-bit version of Windows XP. >> >> Installation choices for 64-bit consumer versions of Windows Vista >> http://support.microsoft.com/kb/932795 >> >> "Windows XP Professional x64 users can purchase an upgrade license for >> the 64-bit version of Windows Vista. However, they must >> perform a clean installation of the operating system." >> > That's just totally incorrect advice. > The 64 bit upgrade version merely checks that you have a valid OS > installed. The installation will proceed as a "clean" install. |
| | #8 (permalink) |
| | Re: vista 64 bit upgrade problems The OP clearly stated: "I am on a Latitude D830 with 4 gig ram, t7700 dual core processor and 160 gig hdd. my system is vista business 32 bit . i bought a 64 bit retail upgrade but it say "Setup can not ru on this version of the Operating System." The OP cannot upgrade his 32-bit version of Vista to a 64-bit version. A "clean install" would be required on an available empty drive or partition. The OP likely does not have "an available empty partition" with a preinstalled 32-bit version of Vista. -- Carey Frisch Microsoft MVP Windows - Shell/User Microsoft Community Newsgroups news://msnews.microsoft.com/ "cvp" wrote: Quote: > Carey Frisch [MVP] wrote: Quote: > > Having a 32-bit installation of Vista does not > > qualify for the upgrade version of the 64-bit version. > > > > Wrong again! > Since you gave the link, which part of > "If you purchase a 64-bit upgrade version of Windows Vista with the > intention of installing on a computer that is running a 32-bit operating > system, you must install Windows Vista by starting the computer from the > 64-bit Vista installation DVD." > and > "The following installed operating systems are eligible for a Windows > Vista upgrade installation: ... > • Windows Vista Home Basic (32-bit and 64-bit) > • Windows Vista Home Premium (32-bit and 64-bit) > • Windows Vista Business (32-bit and 64-bit) > • Windows Vista Ultimate (32-bit and 64-bit)" > > do you not understand? > |
| | #9 (permalink) |
| | Re: vista 64 bit upgrade problems Carey Frisch [MVP] wrote: Quote: > The OP clearly stated: > > "I am on a Latitude D830 with 4 gig ram, t7700 dual core processor and > 160 gig hdd. my system is vista business 32 bit . i bought a 64 bit > retail upgrade but it say > "Setup can not ru on this version of the Operating System." > > The OP cannot upgrade his 32-bit version of Vista to a > 64-bit version. A "clean install" would be required on > an available empty drive or partition. The OP likely > does not have "an available empty partition" with a > preinstalled 32-bit version of Vista. > partition, nor on one with a 32 bit Vista. The existing drive merely has to have enough space on it and the 32 bit system has to be available for inspection.You've obviously never done it if you're making these assertions. |
| | #10 (permalink) |
| | Re: vista 64 bit upgrade problems The OP did not indicate he wished to perform a "clean install" of the 64-bit version of Vista. He wanted to "upgrade" from his 32-bit version to the 64-bit version. -- Carey Frisch Microsoft MVP Windows Shell/User --------------------------------------------------------------- "cvp" <goaway@xxxxxx> wrote in message news:OfFuzu5BIHA.4496@xxxxxx Carey Frisch [MVP] wrote: Quote: > The OP clearly stated: > > "I am on a Latitude D830 with 4 gig ram, t7700 dual core processor and > 160 gig hdd. my system is vista business 32 bit . i bought a 64 bit > retail upgrade but it say > "Setup can not ru on this version of the Operating System." > > The OP cannot upgrade his 32-bit version of Vista to a > 64-bit version. A "clean install" would be required on > an available empty drive or partition. The OP likely > does not have "an available empty partition" with a > preinstalled 32-bit version of Vista. > partition, nor on one with a 32 bit Vista. The existing drive merely has to have enough space on it and the 32 bit system has to be available for inspection.You've obviously never done it if you're making these assertions. |
| vista upgrade ultimate problems | Windows Updates | |||
| vista upgrade problems | Vista General | |||
| Vista -> XP upgrade problems | Vista General | |||
| Sound problems since Vista upgrade | Vista General | |||
| Major Problems with upgrade to vista | Vista General | |||
