| | Strange Little Problem w/ Vista's Screens On a new Toshiba notebook Satellite A135 w/ Vista once in a while a simple movement of a finger on the touch pad will cause the current screen to minimize to the task bar regardless of where the cursor may be at the time. I've tried to re-create the problem by moving around on the touch pad and clicking on screens etc, but it only does it when IT wants to. While not a gamer, I fooled around with one of the on-board games called Mahjong. while playing the game the screen will minimize (smaller) and a few mintues later maximize and this happens perhaps 4-5 times over the course of the game. In this instance it does not minimize to the task bar, it just gets smaller and then jumps up maximized again. I noticed last time I did the Windows update that there was a Synaptics update for the touch pad. W/o researching that I just hoped that would fix it. I've also found nothing pertinent at the Toshiba forums. I tend to believe it may not be a problem w/ the touch pad but rather w/ Vista. Is this a problem that occurs with others? Any ideas or suggestions? Thanks group. -SB |
| | Re: Strange Little Problem w/ Vista's Screens The only way I have found to troubleshoot issues with a touchpad is to remove all of the "tap to click, zones" and other options for the device. The only thing you should have left is a basic, left/right button click and normal movement. Then test to see if the problem behavior is still present. -- Ronnie Vernon Microsoft MVP Windows Shell/User "SB" <slug@xxxxxx> wrote in message news:unZPDCCCIHA.3940@xxxxxx Quote: > On a new Toshiba notebook Satellite A135 w/ Vista once in a while a simple > movement of a finger on the touch pad will cause the current screen to > minimize to the task bar regardless of where the cursor may be at the > time. I've tried to re-create the problem by moving around on the touch > pad and clicking on screens etc, but it only does it when IT wants to. > > While not a gamer, I fooled around with one of the on-board games called > Mahjong. while playing the game the screen will minimize (smaller) and a > few mintues later maximize and this happens perhaps 4-5 times over the > course of the game. In this instance it does not minimize to the task > bar, it just gets smaller and then jumps up maximized again. > > I noticed last time I did the Windows update that there was a Synaptics > update for the touch pad. W/o researching that I just hoped that would > fix it. I've also found nothing pertinent at the Toshiba forums. I tend to > believe it may not be a problem w/ the touch pad but rather w/ Vista. > > Is this a problem that occurs with others? Any ideas or suggestions? > Thanks group. > > -SB |
| vista home premium 32 bit | Re: Strange Little Problem w/ Vista's Screens I have also had the same problem with me Toshiba. So is the sudden minimize/maximize problem a Toshiba issue or vista issue? There seems to be no way to initiate the problem...it occurs randomly when using the touchpad. It is very frustrating to be working on something then suddenly have it minimized. I cant find anyone that knows how to fix the problem. I am using vista premium home addition. If it is a vista problem then it is time to go back to XP or better yet switch to an apple computer. |
| Strange Little Problem w/ Vista's Screens | Vista performance & maintenance | |||
| Blue screens everytime, third party problem? | Vista General | |||
| There is *definitely* a problem with Vista's VPN component | Vista networking & sharing | |||
| Blue screens black screens | Vista installation & setup | |||
| 3 screens problem (1x 9200 SE PCI & 1x 9800 Pro AGP) | Vista hardware & devices | |||
