| | CAD Problem I have inadvertently changed the task manager display to be nothing but a srceen showing the cpu graph. All of the tabs/buttons are gone. I've resized it by dragging etc, but nothing helps. I have to hit ESC to close it as there are no buttons. How can I restore it? |
| | Re: CAD Problem "SB" <slug@xxxxxx> wrote in message news:O9ke7lECIHA.2324@xxxxxx Quote: > I have inadvertently changed the task manager display to be nothing > but a srceen showing the cpu graph. All of the tabs/buttons are gone. > I've resized it by dragging etc, but nothing helps. I have to hit > ESC to close it as there are no buttons. > > How can I restore it? What has this to do with CAD, by the way? ss. |
| | Re: CAD Problem On Sat, 06 Oct 2007 11:48:25 -0700, SB <slug@xxxxxx> wrote: Quote: > I have inadvertently changed the task manager display to be nothing but > a srceen showing the cpu graph. All of the tabs/buttons are gone. I've > resized it by dragging etc, but nothing helps. I have to hit ESC to > close it as there are no buttons. "CAD Problem"? Why is this a CAD problem? You're running in what's called "Small Footprint Mode." To change back and forth from this mode to regular mode, just double-click on the border. -- Ken Blake, Microsoft MVP Windows - Shell/User Please Reply to the Newsgroup |
| | Re: CAD Problem SB wrote: Quote: > I have inadvertently changed the task manager display to be nothing but > a srceen showing the cpu graph. All of the tabs/buttons are gone. I've > resized it by dragging etc, but nothing helps. I have to hit ESC to > close it as there are no buttons. > > How can I restore it? It sounds like you're running Task Manager in "Small Footprint Mode." Simply double-click anywhere along the top or side borders to return to a normal view. Alternatively, pressing <Ctrl>+<Tab> will allow you to cycle between the various displays, and <Alt>+<F4> will close it. Task Manager Menu Bar and Tabs Are Not Visible in Windows XP (Applies to Vista, as well.) http://support.microsoft.com/default...b;en-us;314227 -- Bruce Chambers Help us help you: http://dts-l.org/goodpost.htm http://www.catb.org/~esr/faqs/smart-questions.html They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. ~Benjamin Franklin Many people would rather die than think; in fact, most do. ~Bertrand Russell The philosopher has never killed any priests, whereas the priest has killed a great many philosophers. ~ Denis Diderot |
| | Re: CAD Problem Synapse Syndrome wrote: Quote: > > > What has this to do with CAD, by the way? > > ss. > > In this case, I think the OP means CAD to represent <Crtl>+<Alt>+<Del>, rather than the standard "Computer Aided Design." -- Bruce Chambers Help us help you: http://dts-l.org/goodpost.htm http://www.catb.org/~esr/faqs/smart-questions.html They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. ~Benjamin Franklin Many people would rather die than think; in fact, most do. ~Bertrand Russell The philosopher has never killed any priests, whereas the priest has killed a great many philosophers. ~ Denis Diderot |
| | #6 (permalink) |
| | Re: CAD Problem Ken Blake, MVP wrote: Quote: > On Sat, 06 Oct 2007 11:48:25 -0700, SB <slug@xxxxxx> wrote: > Quote: >> I have inadvertently changed the task manager display to be nothing but >> a srceen showing the cpu graph. All of the tabs/buttons are gone. I've >> resized it by dragging etc, but nothing helps. I have to hit ESC to >> close it as there are no buttons. > > > "CAD Problem"? Why is this a CAD problem? > In this case, I think the OP means "CAD" to represent <Crtl>+<Alt>+<Del>, rather than the standard "Computer Aided Design." -- Bruce Chambers Help us help you: http://dts-l.org/goodpost.htm http://www.catb.org/~esr/faqs/smart-questions.html They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. ~Benjamin Franklin Many people would rather die than think; in fact, most do. ~Bertrand Russell The philosopher has never killed any priests, whereas the priest has killed a great many philosophers. ~ Denis Diderot |
| | #7 (permalink) |
| | Re: CAD Problem On Sun, 07 Oct 2007 10:17:43 -0600, Bruce Chambers <bchambers@xxxxxx> wrote: Quote: > Ken Blake, MVP wrote: Quote: > > On Sat, 06 Oct 2007 11:48:25 -0700, SB <slug@xxxxxx> wrote: > > Quote: > >> I have inadvertently changed the task manager display to be nothing but > >> a srceen showing the cpu graph. All of the tabs/buttons are gone. I've > >> resized it by dragging etc, but nothing helps. I have to hit ESC to > >> close it as there are no buttons. > > > > > > "CAD Problem"? Why is this a CAD problem? > > > Ken -- > > In this case, I think the OP means "CAD" to represent > <Crtl>+<Alt>+<Del>, rather than the standard "Computer Aided Design." Ah! You're probably right. But using a standard abbreviation in a non-standard way is bound to confuse people. -- Ken Blake, Microsoft MVP Windows - Shell/User Please Reply to the Newsgroup |
| | #8 (permalink) |
| | Re: CAD Problem Ken Blake, MVP wrote: Quote: > > > But using a standard abbreviation in a non-standard way is bound to > confuse people. > True, but there are a lot of people who don't know the standard acronyms. -- Bruce Chambers Help us help you: http://dts-l.org/goodpost.htm http://www.catb.org/~esr/faqs/smart-questions.html They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. ~Benjamin Franklin Many people would rather die than think; in fact, most do. ~Bertrand Russell The philosopher has never killed any priests, whereas the priest has killed a great many philosophers. ~ Denis Diderot |
| | #9 (permalink) |
| | Re: CAD Problem On Sun, 07 Oct 2007 14:17:46 -0600, Bruce Chambers <bchambers@xxxxxx> wrote: Quote: > Ken Blake, MVP wrote: Quote: > > > > > > But using a standard abbreviation in a non-standard way is bound to > > confuse people. > > > > True, but there are a lot of people who don't know the standard acronyms. Also true, but all the more reason to be very careful if you try to make up your own abbreviations. If I told someone that I was going to RI next week, there would no reason to expect him to understand that I meant I was going to Rome, Italy (which I am), whether or not he knew that there was a US state called Rhode Island. -- Ken Blake, Microsoft MVP Windows - Shell/User Please Reply to the Newsgroup |
| | #10 (permalink) |
| | Re: CAD Problem Bruce Chambers wrote: Quote: > Synapse Syndrome wrote: Quote: >> >> >> What has this to do with CAD, by the way? >> >> ss. >> > > In this case, I think the OP means CAD to represent > <Crtl>+<Alt>+<Del>, rather than the standard "Computer Aided Design." > > Sorry for any confusion about the acronym. |
| the problem with ndis.sys Blue Screen of Death problem solved? | Vista General | |||
| Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 | Vista mail | |||
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Vista General | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
