Vista - CCC problem
Old 10-06-2007   #1 (permalink)
petar
CCC problem
After boot I get this message:
"You do not have permission to change Catalyst Control Center settings.
Please contact your administrator for further help."
I have my notebook for 2-3 months now and haven't got that message
until now.
Can anyone help?
petar
petar's Profile: http://forums.techarena.in/member.php?userid=32441
View this thread: http://forums.techarena.in/showthread.php?t=829766
Old 10-06-2007   #2 (permalink)
DP
Re: CCC problem
I have a feeling CCC is something specific to your brand of notebook.
"petar" <petar.2y27fc@xxxxxx> wrote in message
newsetar.2y27fc@xxxxxx
> until now.
> Can anyone help?
> petar
Old 10-06-2007   #3 (permalink)
CB
Re: CCC problem
> > until now.
> > Can anyone help?
> > petar
> CCC is the control panel for the ATI graphics card.
C.B.
Old 10-07-2007   #4 (permalink)
Lang Murphy
Re: CCC problem
> until now.
> Can anyone help?
> petar
Well... something's changed. Figuring out what changed is the issue. Update
your video drivers lately? Install any Windows updates lately? Logging on as
the same user that you've used for the last 2-3 months?
Lang
Old 10-07-2007   #5 (permalink)
petar
Re: CCC problem
> settings.
> > until now.
> > Can anyone help?
> > petar
> Update
> on as
> Lang
I update regularly using Win Update but for a week prior to the first
instance of the problem I only installed Definition updates for Win
Defender and two other small programs I got from a trusted source
(http://www.mostich.biz.hr/MostichApp_inst.exe and
http://www.zse.hr/app/ATM.msi).
At the same time I started getting a message from Security Center
saying that it can't find my AV program and that Win Defender is turned
off. I posted that problem in another thread
(http://forums.techarena.in/showthrea...=1#post3212440).
I always log on the same way, I have only one account created.
petar
Old 10-08-2007   #6 (permalink)
Lang Murphy
Re: CCC problem
"petar" <petar.2y3abg@xxxxxx> wrote in message
newsetar.2y3abg@xxxxxx
>> settings.
>> > until now.
>> > Can anyone help?
>> > petar
>> Update
>> on as
>> Lang
> petar
Well, I must admit I don't have an answer for you. Something changed,
obviously. Whether you can backtrack to a point prior to THE change, using
either restore points or backups, is unknown to me.
Good luck,
Lang
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! Vista General
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
