| | Saving vista from its blunders> Solution for the COPY problem I knew about this program for a while as long as one that has saved many people called totalcopy (not compatible with vista though) This one seems like it is compatible with vista... I have not tried it yet, but it seems that this will solve the DREADED vista copy and move problem... I will test this later on.. but if you try it please provide feedback with your experience see here (free and vista compatible) http://www.codesector.com/teracopy.asp TeraCopy is a compact program designed to copy and move files at the maximum possible speed, also providing you with a lot of features: Copy files faster. TeraCopy uses dynamically adjusted buffers to reduce seek times. Asynchronous copy speeds up file transfer between two physical hard drives. Pause and resume file transfers. Pause copy process at any time to free up system resources and continue with a single click. Error recovery. In case of copy error, TeraCopy will try several times and in the worse case just skips the file, not terminating the entire transfer. Interactive file list. TeraCopy shows failed file transfers and lets you fix the problem and recopy only problem files. Shell integration. TeraCopy can completely replace Explorer copy and move functions, allowing you work with files as usual. » Download TeraCopy - Free for Home Users |
| | Re: Saving vista from its blunders> Solution for the COPY problem To further help you all here are 2 screenshots I made (under XP though but it must be the same under vista also) that show how to use this tool You can use the RIGHT CLICK and drag and drop files and then when you release the mouse button a menu pops up like this: http://img131.imageshack.us/img131/4439/sshot5dx8.jpg Or just simply use the context menu (right click) http://img131.imageshack.us/img131/494/sshot6ez2.jpg I will test this under vista too soon.. hope you like.. :-) "Thai Berry (U.S.)" <Thai@xxxxxx> wrote in message news:470a3fc4@xxxxxx-privat.org... Quote: >I knew about this program for a while as long as one that has saved many >people called totalcopy (not compatible with vista though) > > This one seems like it is compatible with vista... I have not tried it > yet, but it seems that this will solve > the DREADED vista copy and move problem... > > I will test this later on.. but if you try it please provide feedback with > your experience > > see here (free and vista compatible) > > http://www.codesector.com/teracopy.asp > > TeraCopy is a compact program designed to copy and move files at the > maximum possible speed, also providing you with a lot of features: > Copy files faster. TeraCopy uses dynamically adjusted buffers to reduce > seek times. Asynchronous copy speeds up file transfer between two physical > hard drives. > > Pause and resume file transfers. Pause copy process at any time to free up > system resources and continue with a single click. > > Error recovery. In case of copy error, TeraCopy will try several times and > in the worse case just skips the file, not terminating the entire > transfer. > > Interactive file list. TeraCopy shows failed file transfers and lets you > fix the problem and recopy only problem files. > > Shell integration. TeraCopy can completely replace Explorer copy and move > functions, allowing you work with files as usual. > » Download TeraCopy - Free for Home Users > |
| home premium vista (64bit) | Re: Saving vista from its blunders> Solution for the COPY problem i just tryed this. i ran vista copy and TeraCopy .starting with TeraCopy and copying 4gig from my f drive to my desktop .right as TeraCopy started i started vista copy copying the same files at the same time to a desktop Folder and vista was done long before teracopy? mike |
| | Re: Saving vista from its blunders> Solution for the COPY problem Oh do not do them at the same time... do one type of copy and count the time needed then try the other type of copy (plain vista kind) and count the time needed Use the same files and the same location to location in the same direction then compare the 2 times needed. That is a better way to compare. I have not done this yet.. so if you could provide feedback it would be good... "scrooge" <scrooge.2y58x1@xxxxxx-mx.forums.net> wrote in message news:scrooge.2y58x1@xxxxxx-mx.forums.net... Quote: > > i just tryed this. i ran vista copy and TeraCopy .starting with > TeraCopy > and copying 4gig from my f drive to my desktop .right as TeraCopy > started > i started vista copy copying the same files at the same time to a > desktop Folder and vista was done long before teracopy? > mike > > > -- > scrooge |
| | Re: Saving vista from its blunders> Solution for the COPY problem Stop using other people as YOUR guinea pigs! Test the software yourself; or are you too gutless? "Thai Berry (U.S.)" wrote: Quote: > Oh do not do them at the same time... > > do one type of copy and count the time needed > > then try the other type of copy (plain vista kind) and count the time needed > > Use the same files and the same location to location in the same direction > > then compare the 2 times needed. > > That is a better way to compare. > > I have not done this yet.. so if you could provide feedback it would be > good... > > > > "scrooge" <scrooge.2y58x1@xxxxxx-mx.forums.net> wrote in message > news:scrooge.2y58x1@xxxxxx-mx.forums.net... Quote: > > > > i just tryed this. i ran vista copy and TeraCopy .starting with > > TeraCopy > > and copying 4gig from my f drive to my desktop .right as TeraCopy > > started > > i started vista copy copying the same files at the same time to a > > desktop Folder and vista was done long before teracopy? > > mike > > > > > > -- > > scrooge > > |
| | #6 (permalink) |
| | Re: Saving vista from its blunders> Solution for the COPY problem Thai Berry (U.S.) wrote: Quote: > I knew about this program for a while as long as one that has saved many > people called totalcopy (not compatible with vista though) > > This one seems like it is compatible with vista... I have not tried it yet, > but it seems that this will solve > the DREADED vista copy and move problem... > > I will test this later on.. but if you try it please provide feedback with > your experience > > see here (free and vista compatible) > > http://www.codesector.com/teracopy.asp > > TeraCopy is a compact program designed to copy and move files at the maximum > possible speed, also providing you with a lot of features: > Copy files faster. TeraCopy uses dynamically adjusted buffers to reduceseek > times. Asynchronous copy speeds up file transfer between two physical hard > drives. > > Pause and resume file transfers. Pause copy process at any time to freeup > system resources and continue with a single click. > > Error recovery. In case of copy error, TeraCopy will try several times and > in the worse case just skips the file, not terminating the entire transfer. > > Interactive file list. TeraCopy shows failed file transfers and lets you fix > the problem and recopy only problem files. > > Shell integration. TeraCopy can completely replace Explorer copy and move > functions, allowing you work with files as usual. > » Download TeraCopy - Free for Home Users > > this sh*t on yourself before foisting it on some unsuspecting user. Frank wanna dance? |
| | #7 (permalink) |
| | Re: Saving vista from its blunders> Solution for the COPY problem thats a smart thing to do,,install all that side crap..uncle bills vista is going to let that stuff work..dont worry..lol vista is bad enough with out installing that kind of crap..if uncle bill is not geting a cut.what ever you install like that is not going to work..its going to drive your computer and you crazy.. "Thai Berry (U.S.)" wrote: Quote: > To further help you all here are 2 screenshots I made (under XP though but > it must be the same under vista also) that show how to use this tool > You can use the RIGHT CLICK and drag and drop files and then when you > release the mouse button > a menu pops up like this: > http://img131.imageshack.us/img131/4439/sshot5dx8.jpg > > Or just simply use the context menu (right click) > > http://img131.imageshack.us/img131/494/sshot6ez2.jpg > > I will test this under vista too soon.. > > > hope you like.. :-) > > > > > "Thai Berry (U.S.)" <Thai@xxxxxx> wrote in message > news:470a3fc4@xxxxxx-privat.org... Quote: > >I knew about this program for a while as long as one that has saved many > >people called totalcopy (not compatible with vista though) > > > > This one seems like it is compatible with vista... I have not tried it > > yet, but it seems that this will solve > > the DREADED vista copy and move problem... > > > > I will test this later on.. but if you try it please provide feedback with > > your experience > > > > see here (free and vista compatible) > > > > http://www.codesector.com/teracopy.asp > > > > TeraCopy is a compact program designed to copy and move files at the > > maximum possible speed, also providing you with a lot of features: > > Copy files faster. TeraCopy uses dynamically adjusted buffers to reduce > > seek times. Asynchronous copy speeds up file transfer between two physical > > hard drives. > > > > Pause and resume file transfers. Pause copy process at any time to free up > > system resources and continue with a single click. > > > > Error recovery. In case of copy error, TeraCopy will try several times and > > in the worse case just skips the file, not terminating the entire > > transfer. > > > > Interactive file list. TeraCopy shows failed file transfers and lets you > > fix the problem and recopy only problem files. > > > > Shell integration. TeraCopy can completely replace Explorer copy and move > > functions, allowing you work with files as usual. > > » Download TeraCopy - Free for Home Users > > > > |
| Solution for saving a wmv file | Vista music pictures video | |||
| Solution to WMP 11 problem in Vista | General Discussion | |||
| Using Vista x64.... need a solution for my problem | Vista General | |||
| Possible Solution To Vista Problem | Vista installation & setup | |||
| User Interface Blunders | Vista General | |||
