Vista - USB power supply issue causes BSOD but only during Vista boot!
Old 10-08-2007   #11 (permalink)
Jon Davis
Re: USB power supply issue causes BSOD but only during Vista boot!
Sure enough, it was VMWare Workstation 6. I uninstalled VMWare and installed
the update referenced by Kue2, rebooted (with USB stuff all plugged in), and
no blue screen. I rebooted again, still no bluescreen. I reinstalled VMWare,
got the INTERNAL_POWER_FAILURE error. So I'm uninstalling VMWare again, for
good.
I do need VMWare but fortunately this isn't my only computer, and the other
computers running Vista and VMWare don't have this problem.
Jon
"Jon Davis" <jon@xxxxxx> wrote in message
news:u34uwFfCIHA.5280@xxxxxx
Quote:
> Someone reported that Vista + VMWare + Wireless keyboard/mouse ==
> INTERNAL_POWER_FAILURE error. But that was on Vista x64. I have a wireless
> keyboard/mouse, I just uninstalled VMWare. (Crossing fingers.)
> http://www.google.com/search?q=internal_power_error+usb
> Jon
> "Richard Urban" <richardurbanREMOVETHIS@xxxxxx> wrote in message
> news:uaLMcbeCIHA.1164@xxxxxx
Quote:
>> This is not an issue that others are reporting to my knowledge. I would
>> think that there is some sort of hardware incompatibility between the hub
>> and the computer, or the drivers (if supplied) and Vista.
>> Regards,
>> Richard Urban
>> Microsoft MVP Windows Shell/User
>> (For email, remove the obvious from my address)
>> news:ubZYyPeCIHA.4836@xxxxxx
Quote:
>>>I have a weird problem. I don't want to replace my motherboard (MSI P965
>>>Platinum), but I don't know what else this could be, except perhaps
>>>Windows Vista.
>>> When I boot up, around the time that it switches to high-resolution view
>>> (before login) I get a BSOD with the error being
>>> "INTERNAL_POWER_FAILURE". The BSOD goes away if I boot with ALL USB
>>> devices disconnected.
>>> But here's where I suspect it's Vista: once I get to the login screen, I
>>> can connect my USB hub and carry on like there's no problem.
>>> My USB hub is a the absolute best $60 high-powered USB hub I could find
>>> (Dr. Bott T7Hub), and it replaces a generic high-power USB hub I had
>>> also tried. I've found that the problem still exists even if I just hook
>>> the keyboard and mouse alone directly to the computer and no USB hub,
>>> and the wireless USB keyboard/mouse combo is also newly replaced from
>>> some old legacy USB keyboard and PS/2 mouse from long after the problem
>>> arose.
>>> I've replaced the chassis power supply as well, going up from a 500W
>>> Antec unit to a 600W unit.
>>> It seems Vista is doing some lame equalibrium test during boot-up and
>>> only during boot-up, and puking when it sees there's something odd. But,
>>> hello, Microsoft, that's the BIOS's job, not yours!! I wonder if there's
>>> some way to disable this check?
>>> Meanwhile, I've been using my compuer for about ten months now, just
>>> pulling the plug on the USB hub uplink until I get to the login screen.
>>> Jon
Old 10-08-2007   #12 (permalink)
Jon Davis
VMWare and wireless keyboard/mouse and Vista = INTERNAL_POWER_FAILURE
Updated Subject to help others find this.
news:%23r0lVCgCIHA.3848@xxxxxx
> installed the update referenced by Kue2, rebooted (with USB stuff all
> plugged in), and no blue screen. I rebooted again, still no bluescreen. I
> reinstalled VMWare, got the INTERNAL_POWER_FAILURE error. So I'm
> uninstalling VMWare again, for good.
> other computers running Vista and VMWare don't have this problem.
> Jon
>> wireless keyboard/mouse, I just uninstalled VMWare. (Crossing fingers.)
>> Jon
>>> hub and the computer, or the drivers (if supplied) and Vista.
>>> Regards,
>>> Richard Urban
>>>>Windows Vista.
>>>> view (before login) I get a BSOD with the error being
>>>> I can connect my USB hub and carry on like there's no problem.
>>>> hook the keyboard and mouse alone directly to the computer and no USB
>>>> hub, and the wireless USB keyboard/mouse combo is also newly replaced
>>>> from some old legacy USB keyboard and PS/2 mouse from long after the
>>>> problem arose.
>>>> But, hello, Microsoft, that's the BIOS's job, not yours!! I wonder if
>>>> there's some way to disable this check?
>>>> Jon
Power Supply Change Issue General Discussion
Power Supply or Vista Bug? General Discussion
When shut down Vista, must disconnect the power supply and reconnect before booting General Discussion
Has Windows Vista it’s own UPS (Un-interrupted Power Supply) softw Vista General
Install UPS (uninterruptable power supply) in Vista Vista hardware & devices
