Vista Tutorial - USB power supply issue causes BSOD but only during Vista boot!
Old 10-08-2007   #1 (permalink)
Jon Davis
Guest
I have a weird problem. I don't want to replace my motherboard (MSI P965
Platinum), but I don't know what else this could be, except perhaps Windows
Vista.
When I boot up, around the time that it switches to high-resolution view
(before login) I get a BSOD with the error being "INTERNAL_POWER_FAILURE".
The BSOD goes away if I boot with ALL USB devices disconnected.
But here's where I suspect it's Vista: once I get to the login screen, I can
connect my USB hub and carry on like there's no problem.
My USB hub is a the absolute best $60 high-powered USB hub I could find (Dr.
Bott T7Hub), and it replaces a generic high-power USB hub I had also tried.
I've found that the problem still exists even if I just hook the keyboard
and mouse alone directly to the computer and no USB hub, and the wireless
USB keyboard/mouse combo is also newly replaced from some old legacy USB
keyboard and PS/2 mouse from long after the problem arose.
I've replaced the chassis power supply as well, going up from a 500W Antec
unit to a 600W unit.
It seems Vista is doing some lame equalibrium test during boot-up and only
during boot-up, and puking when it sees there's something odd. But, hello,
Microsoft, that's the BIOS's job, not yours!! I wonder if there's some way
to disable this check?
Meanwhile, I've been using my compuer for about ten months now, just pulling
the plug on the USB hub uplink until I get to the login screen.
Jon
Old 10-08-2007   #2 (permalink)
Richard Urban
Guest
Re: USB power supply issue causes BSOD but only during Vista boot!
This is not an issue that others are reporting to my knowledge. I would
think that there is some sort of hardware incompatibility between the hub
and the computer, or the drivers (if supplied) and Vista.
Regards,
Richard Urban
"Jon Davis" <jon@xxxxxx> wrote in message
news:ubZYyPeCIHA.4836@xxxxxx
>Vista.
> can connect my USB hub and carry on like there's no problem.
> (Dr. Bott T7Hub), and it replaces a generic high-power USB hub I had also
> tried. I've found that the problem still exists even if I just hook the
> keyboard and mouse alone directly to the computer and no USB hub, and the
> wireless USB keyboard/mouse combo is also newly replaced from some old
> legacy USB keyboard and PS/2 mouse from long after the problem arose.
> pulling the plug on the USB hub uplink until I get to the login screen.
> Jon
Old 10-08-2007   #3 (permalink)
Peadar
Guest
RE: USB power supply issue causes BSOD but only during Vista boot!
Hmmm i had a similar problem, i found out that a USB device, was sharing the
same IRQ as another device on my computer, causing it to lock up and get the
BSOD, i had to manually change the IRQ settings, it may not be the problem
but u cud give it a go, go to start-control panel-system-device manager-under
the USB devices right click on each one and click on Resource, you will then
see a number next to IRQ, make sure than no devices under that USB list has
the same number, if so, you can change the conflicting device numberanywhere
between 12-15 (these are open IRQS) worth a shot.
> Vista.
> Jon
Old 10-08-2007   #4 (permalink)
matt hopkins
Guest
sounds to me like the problem could be with your internal usb controller try
updating it on the device manager also i would try sticking a multimeter to
your power supply inputs and outputs sure youll be able to find the correct
voltage for your controllers on your internet.
>Vista.
> Jon
Old 10-08-2007   #5 (permalink)
Kue2
Guest
try here http://support.microsoft.com/kb/941600
>Vista.
> Jon
Old 10-08-2007   #6 (permalink)
Jon Davis
Guest
Do IRQ conflicts cause INTERNAL_POWER_FAILURE error?
Jon
"Peadar" <Peadar@xxxxxx> wrote in message
news:179075C2-D551-445A-A741-8A254CB5067C@xxxxxx
> the
> the
> manager-under
> then
> has
> numberanywhere
>> Windows
>> Vista.
>> can
>> (Dr.
>> tried.
>> Antec
>> only
>> hello,
>> way
>> pulling
>> Jon
Old 10-08-2007   #7 (permalink)
Jon Davis
Guest
Right, hence motherboard replacement, which I don't want to do because once
I plug in and log in, I can use the computer normally. Seems like Vista
should be the one to behave.
Jon
"matt hopkins" <hopkins822@xxxxxx> wrote in message
news:64DF9ACA-724D-4A60-A1C0-17B51CC59B8F@xxxxxx
> try updating it on the device manager also i would try sticking a
> multimeter to your power supply inputs and outputs sure youll be able to
> find the correct voltage for your controllers on your internet.
>>Windows Vista.
>> "INTERNAL_POWER_FAILURE". The BSOD goes away if I boot with ALL USB
>> Antec unit to a 600W unit.
>> only during boot-up, and puking when it sees there's something odd. But,
>> hello, Microsoft, that's the BIOS's job, not yours!! I wonder if there's
>> some way to disable this check?
>> Jon
Old 10-08-2007   #8 (permalink)
Jon Davis
Guest
Thanks. None of those relate to INTERNAL_POWER_FAILURE
Jon
"Kue2" <h.j.kennedy@xxxxxx> wrote in message
news:ePBpFeeCIHA.3848@xxxxxx
>>Windows Vista.
>> Jon
Old 10-08-2007   #9 (permalink)
Jon Davis
Guest
Someone reported that Vista + VMWare + Wireless keyboard/mouse ==
INTERNAL_POWER_FAILURE error. But that was on Vista x64. I have a wireless
keyboard/mouse, I just uninstalled VMWare. (Crossing fingers.)
http://www.google.com/search?q=internal_power_error+usb
Jon
"Richard Urban" <richardurbanREMOVETHIS@xxxxxx> wrote in message
news:uaLMcbeCIHA.1164@xxxxxx
> Regards,
> Richard Urban
>>Windows Vista.
>> Jon
Old 10-08-2007   #10 (permalink)
Jon Davis
Guest
... But I'm downloading and installing anyway
Jon
news:%23e1LTEfCIHA.1212@xxxxxx
> Jon
>>>Windows Vista.
>>> also tried. I've found that the problem still exists even if I just hook
>>> the keyboard and mouse alone directly to the computer and no USB hub,
>>> and the wireless USB keyboard/mouse combo is also newly replaced from
>>> some old legacy USB keyboard and PS/2 mouse from long after the problem
>>> arose.
>>> Jon
Power Supply Change Issue General Discussion
Power Supply or Vista Bug? General Discussion
When shut down Vista, must disconnect the power supply and reconnect before booting General Discussion
Has Windows Vista it’s own UPS (Un-interrupted Power Supply) softw Vista General
Install UPS (uninterruptable power supply) in Vista Vista hardware & devices
