| | External HDD driver?? USB to ATA/ATAPI bridge?? HELP PLEASE im having a problem with my external hdd, i have two, one WD external works fine with vista, then i go to use my new one (formatted it using xp etc_) on my laptop with vista and it wont pick it up >< i mean surely something natively supported by xp would be natively supported by vista as well. Unless im doing something wrong....lol...but my usb mouse and other external etc etc was all picked up fine. I plug my hdd in and it comes up installing drivers, then says windows needs to install software for your USB to ATA/ATAPI bridge, then i click locate and and install automatically, then it just goes into USB to ATA/ATAPI bridge driver failed. i have googled the driver with out luck. i do not have a driver cd. the brand is NEXT with a standard 500gig seagate drive in it... is this something that ive done wrong?? Im running vista 32bit home premium on a dell xps laptop. Any help would be awesome guys |
| USB to Serial-ATA bridge driver not found | Vista General | |||
| USB SATA drive says cannot find "USB to Serial-ATA bridge driver" | Vista hardware & devices | |||
| How to install "PCI to PCI Bridge" driver, associated with WinTV card installation? | Vista hardware & devices | |||
| viata installation problem atapi cd-rom driver | Vista installation & setup | |||
| Atapi CD/DVD-Rom Driver Corruption | Vista installation & setup | |||
