Vista - Start menu, right pane, music icon does not work
Old 10-10-2007   #1 (permalink)
StrongDVM
My music icon does not open the music folder. Right clicking on the music
icon and selecting properties shows that there is nothing. Opening the start
menu properties shows that there is no listing for music to select also. How
can I fix this?
Old 10-10-2007   #2 (permalink)
Andre Da Costa[ActiveWin]
Re: Start menu, right pane, music icon does not work
Try pointing back to the User directory for Music under your Accounts
folder.
Properties > Location (tab) C:\Users\your name\Music
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
"StrongDVM" <StrongDVM@xxxxxx> wrote in message
news:8C967623-CE19-4DB4-9AC5-2E07C93F5CF7@xxxxxx
> start
> How
> can I fix this?
Old 10-10-2007   #3 (permalink)
StrongDVM
It won't allow me to do anything. Right clicking the icon on the start menu
does not give me the ability to edit.
"Andre Da Costa[ActiveWin]" wrote:
> folder.
> Andre
> > start
> > How
> > can I fix this?
Old 10-10-2007   #4 (permalink)
Uncheck the Read-only attribute under General tab and try again.
Andre
news6129837-2C38-4171-95BE-B7C0E56ECE7B@xxxxxx
> menu
>> folder.
>> Andre
>> > music
>> > start
>> > also.
>> > How
>> > can I fix this?
Old 10-11-2007   #5 (permalink)
Ramesh, MS-MVP
See:
Nothing happens when you click on a shell folder link in the Windows Vista Start menu:
http://www.winhelponline.com/articles/180/1/
Regards,
Ramesh Srinivasan, Microsoft MVP [Windows Shell/User]
Windows® Troubleshooting http://www.winhelponline.com
"StrongDVM" <StrongDVM@xxxxxx> wrote in message news:8C967623-CE19-4DB4-9AC5-2E07C93F5CF7@xxxxxx
can I fix this?
Old 10-12-2007   #6 (permalink)
StrongDVM
Thanks, that was the solution. Once I restarted the problem was fixed.
"Ramesh, MS-MVP" wrote:
Quote:
> See:
> Regards,
> can I fix this?
Old 10-16-2007   #7 (permalink)
Ramesh, MS-MVP
You're welcome!
Regards,
"StrongDVM" <StrongDVM@xxxxxx> wrote in message news:CB58829F-DBB6-43AB-9CDF-D298B0514B1C@xxxxxx
Quote:
> See:
> Regards,
> can I fix this?
Music link in Right Pane of Start Menu Vista music pictures video
Music icon not working in menu start Vista account administration
Start Menu Right Pane Vista General
START MENU RIGHT PANE LINK OR MENU OPTION Vista General
Start Menu right pane Vista General
