Vista - Re: recent upgrades has caused ie7 to not work
Old 10-11-2007   #1 (permalink)
c.santee
On Oct 11, 12:38 pm, staceylynn424
<staceylynn...@xxxxxx> wrote:
Quote:
> Microsoft upgrades that installed yesterday have caused IE7 to stop working.
> I have internet connection to all my other applications with the exception of
> ie7. We can get ie7 to work if we do a system restore to the previous day,
> but run into the same problem whenever the computer tries to auto update
> microsoft. We have turned off auto update, but would like to know why this
> is happening?
Stacey,
Just so you know it's not you, same thing happened to us. We have
Vista Business and Ultimate Systems using Spy Sweeper as AV. w/
Google, Yahoo, Live and Contribute tool bars was wondering if you had
anything in common with our systems. - CES
Old 10-11-2007   #2 (permalink)
c.santee
> > is happening?
> Stacey,
All,
A workaround can be found at:
http://groups.google.com/group/micro...932f7d840e5360
But in short you need to remove the KB939653 update. Please post any
message to that forum. - CES
Old 10-11-2007   #3 (permalink)
groomsmom5
you are not the only one that has happened too i can access ie7 but when i
want to change to any thing else and close a program out it stops working and
comes up with a white page then an error report i have sent error report like
so many times i am getting discussed with doing it i am thinking about
removing the update and then restoring ie7 back to the way i had it before if
i knew how to do it
> > is happening?
> Stacey,
Clear Recent ites doesn't work... Vista General
"Recent" short cut doesnt work anymore Vista General
SP 1 caused my Nic to not work Vista General
Upgrades I would like to see. Vista mail
there is NO upgrade path from XP. No upgrades. No upgrades???? Vista General
