| | Low disk space free problem I'm usually running low (~5GB free of 60GB) on free disk space, but I've noticed an 'odd' behaviour with Vista that has just hit as a 'critical' problem. When I copy files off of my computer over a network to my file server my free disk space drops. Today I was copying a 8GB VirtualPC disk image so I could compress it and copy it back and I've run out of disk space, which has caused all sorts of problems with other applications that periodically write to the disk, including other file copy / move opperations off of the computer over the network. Furthering the problem, when the copy completed the disk space used by the copy was not released. As you might assume, I'm a bit hesitant to reboot in case it still isn't cleared and the OS crashes when it fails that initial read. I'm quite sure this isn't a pagefile problem as I don't use a dynamic pagefile. Where is Vista caching this so I can delete it? How can I stop it from doing this in the future? I didn't think I'd find Windows Explorer cyclicly crashing and recovering because there's no free disk space left my Vista showstopper, but here it is, and I need to know how to clean up after the OS if it's not going to do so itself. |
| No free disk space error even though there is enough disk space on Windows Vista x64 | Vista installation & setup | |||
| Re: free disk space is decreasing | Vista security | |||
| Free Disk Space | PowerShell | |||
| Query disk free space.... | PowerShell | |||
| Out of disk space error at installations, though 100 Gb free space | Vista General | |||
