Vista - Really messed up problem
Old 10-12-2007   #1 (permalink)
Sora267
I've had my new computer for about 2 months now, and everything's been going
great....Until I got home from school. (I'm on my old computer now.)
Anyways, this new computer is running Windows Vista Home Premium. I had put
it to Hibernate last night, and when I get home, I turn it on. That little
loading bar thing shows up like normal, then the screen goes dark like it
does before the login screen shows up. Except, it stays that way for nearly
30 minutes, which is when I get mad and force shut it down using the power
button. I then turn it on and am asked if I want to use Safe Mode. So, I
choose Safe Mode and it lets me log on. So then, I do a System Restore to
yesterday afternoon, before I updated AIM. I then go to restart my
computer....Same thing happens. I force shut it down, restart in Safe Mode,
then run a Virus scan. Nothing. So then I shut down my computer, turn it back
on, and now it's been at a dark screen for about 20 minutes while I do my
normal stuff on this computer.
Has this happened to anyone before, and if so, what fixed it?
Old 10-12-2007   #2 (permalink)
Sora267
RE: Really messed up problem
Well, after booting into Safe Mode and checking the Event Viewer, it seems
the problem source is called "Kernel-Power". Basically, it says: "The last
sleep transition was unsuccessful. This error could be caused if the system
stopped responding, failed, or lost power during the sleep transition."
Something must have messed up when I was putting my computer to Hibernate.
Now that I know what the problem is, does anyone know how to fix it?
Old 10-12-2007   #3 (permalink)
Andre Da Costa[ActiveWin]
Re: Really messed up problem
Boot using the "Last known Good startup" and see if it corrects the issue.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
"Sora267" <Sora267@xxxxxx> wrote in message
news:122A23AA-3452-42CA-84F7-40FF38422F5A@xxxxxx
> system
> "Sora267" wrote:
>> going
>> put
>> little
>> nearly
>> power
>> Mode,
>> back
Old 10-12-2007   #4 (permalink)
Sora267
I chose it, then got the loading bar.....Same thing happened. =\
"Andre Da Costa[ActiveWin]" wrote:
> Andre
> > system
> > "Sora267" wrote:
> >> going
> >> put
> >> little
> >> nearly
> >> power
> >> Mode,
> >> back
Old 10-12-2007   #5 (permalink)
Sora267
Well, I found a setting that lets me revert back to original factory
settings, so I backed up everything onto my iPod. I'll try this, and if it
doesn't work...I'll just CRY.
> > Andre
> > > system
> > >> going
> > >> put
> > >> little
> > >> nearly
> > >> power
> > >> Mode,
> > >> back
Old 10-12-2007   #6 (permalink)
Try doing a system repair. Boot off your Windows Vista Home Premium DVD, go
into the Recovery Environment, choose Repair, > select your installation and
do a Repair startup.
Andre
news:AA5208D7-45AB-4C86-81BA-C41D20A82E95@xxxxxx
>> > issue.
>> > Andre
>> > > seems
>> > > last
>> > > system
>> > > transition."
>> > > Hibernate.
>> > >> been
>> > >> going
>> > >> had
>> > >> put
>> > >> little
>> > >> like it
>> > >> nearly
>> > >> power
>> > >> So, I
>> > >> Restore to
>> > >> Safe
>> > >> Mode,
>> > >> turn it
>> > >> back
>> > >> do my
Old 10-12-2007   #7 (permalink)
Sora267
Home Premium came pre-installed on this, so I could already to the repair
startup. That didn't work either, so I just reformatted the drive using the
HP diagnostic tool that was installed on this thing.
> Andre
> >> > issue.
> >> > Andre
> >> > > seems
> >> > > last
> >> > > system
> >> > > transition."
> >> > > Hibernate.
> >> > >> been
> >> > >> going
> >> > >> had
> >> > >> put
> >> > >> little
> >> > >> like it
> >> > >> nearly
> >> > >> power
> >> > >> So, I
> >> > >> Restore to
> >> > >> Safe
> >> > >> Mode,
> >> > >> turn it
> >> > >> back
> >> > >> do my
Old 10-12-2007   #8 (permalink)
Sora267
Okay, I just rebooted and the same thing happened. O_o.
> > Andre
> > >> > issue.
> > >> > Andre
> > >> > > seems
> > >> > > last
> > >> > > system
> > >> > > transition."
> > >> > > Hibernate.
> > >> > >> been
> > >> > >> going
> > >> > >> had
> > >> > >> put
> > >> > >> little
> > >> > >> like it
> > >> > >> nearly
> > >> > >> power
> > >> > >> So, I
> > >> > >> Restore to
> > >> > >> Safe
> > >> > >> Mode,
> > >> > >> turn it
> > >> > >> back
> > >> > >> do my
Old 10-13-2007   #9 (permalink)
Its time to contact HP support about this issue. Looks like its beyond
Windows.
Andre
news:9459A285-169C-4DA6-81BA-015CCAAAF037@xxxxxx
>> the
>> > DVD, go
>> > installation and
>> > Andre
>> > > if it
>> > >> > the
>> > >> > issue.
>> > >> > Andre
>> > >> > > Viewer, it
>> > >> > > seems
>> > >> > > "The
>> > >> > > last
>> > >> > > the
>> > >> > > system
>> > >> > > transition."
>> > >> > > Hibernate.
>> > >> > > it?
>> > >> > >> everything's
>> > >> > >> been
>> > >> > >> going
>> > >> > >> now.)
>> > >> > >> Premium. I
>> > >> > >> had
>> > >> > >> put
>> > >> > >> That
>> > >> > >> little
>> > >> > >> dark
>> > >> > >> like it
>> > >> > >> way for
>> > >> > >> nearly
>> > >> > >> using the
>> > >> > >> power
>> > >> > >> Mode.
>> > >> > >> So, I
>> > >> > >> Restore to
>> > >> > >> my
>> > >> > >> in
>> > >> > >> Safe
>> > >> > >> Mode,
>> > >> > >> computer,
>> > >> > >> turn it
>> > >> > >> back
>> > >> > >> while I
>> > >> > >> do my
Old 10-13-2007   #10 (permalink)
Sora267
Reformatting fixed the problem, but I just went to change the screen
resolution and screen went dark.
If it doesn't come back I guess I'll contact HP support.
> Windows.
> Andre
> >> the
> >> > DVD, go
> >> > installation and
> >> > Andre
> >> > > if it
> >> > >> > the
> >> > >> > issue.
> >> > >> > Andre
> >> > >> > > Viewer, it
> >> > >> > > seems
> >> > >> > > "The
> >> > >> > > last
> >> > >> > > the
> >> > >> > > system
> >> > >> > > transition."
> >> > >> > > Hibernate.
> >> > >> > > it?
> >> > >> > >> everything's
> >> > >> > >> been
> >> > >> > >> going
> >> > >> > >> now.)
> >> > >> > >> Premium. I
> >> > >> > >> had
> >> > >> > >> put
> >> > >> > >> That
> >> > >> > >> little
> >> > >> > >> dark
> >> > >> > >> like it
> >> > >> > >> way for
> >> > >> > >> nearly
> >> > >> > >> using the
> >> > >> > >> power
> >> > >> > >> Mode.
> >> > >> > >> So, I
> >> > >> > >> Restore to
> >> > >> > >> my
> >> > >> > >> in
> >> > >> > >> Safe
> >> > >> > >> Mode,
> >> > >> > >> computer,
> >> > >> > >> turn it
> >> > >> > >> back
> >> > >> > >> while I
> >> > >> > >> do my
I messed up my display i think. Vista General
i think i messed something up... Vista General
messed up icons Vista General
my cd/dvd drive is messed up Vista hardware & devices
USB messed up Vista installation & setup
