| Guest | Portable devices HELP i have a problem with my mp3 , i connect the mp3 to the usb cable and plug the usb cable in. after that a pop-up appears i click the one to sync it then i go into My Computer and click the name of my device then it opens a folder saying SD/MMC card(which i dont have) or audio im not sure of which one to click so i try both , it says i have no songs on my mp3 when i no i have over 100! my question is how do i put songs onto my mp3, what file do i click and any necessary procedures i need to go through(please include steps to these procedures) and how do i see what songs i have on my mp3 |
| Guest | Re: Portable devices HELP You might want to post this in a more appropriate Vista newsgroup relating to your issue: microsoft.public.windows.vista.hardware_devices -- Andre Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide: http://adacosta.spaces.live.com/blog...3DB!9709.entry "Krisy" <Krisy@xxxxxx> wrote in message news:EF7850D0-9FB1-4BD7-B537-B4923BBB0891@xxxxxx Quote: >i have a problem with my mp3 , i connect the mp3 to the usb cable and plug > the usb cable in. after that a pop-up appears i click the one to sync it > then i go into My Computer and click the name of my device then it opens a > folder saying SD/MMC card(which i dont have) or audio im not sure of which > one to click so i try both , it says i have no songs on my mp3 when i no i > have over 100! my question is how do i put songs onto my mp3, what file do > i > click and any necessary procedures i need to go through(please include > steps > to these procedures) and how do i see what songs i have on my mp3 |
| Guest | Re: Portable devices HELP Krisy wrote: Quote: > i have a problem with my mp3 , i connect the mp3 to the usb cable and plug > the usb cable in. after that a pop-up appears i click the one to sync it > then i go into My Computer and click the name of my device then it opens a > folder saying SD/MMC card(which i dont have) or audio im not sure of which > one to click so i try both , it says i have no songs on my mp3 when i no i > have over 100! my question is how do i put songs onto my mp3, what file do i > click and any necessary procedures i need to go through(please include steps > to these procedures) and how do i see what songs i have on my mp3 Did you install the software first? -- Wim Hekken ;-) |
| Portable Devices | General Discussion | |||
| Access to vista component devices of playback devices likemicrophone, linein, front mic etc in vc++ | Vista hardware & devices | |||
| Using portable devices with Windows Vista Home Premium | Vista hardware & devices | |||
| getting songs on portable devices | Vista hardware & devices | |||
