Vista - Acrobat Reader 7 problems
Old 10-13-2007   #1 (permalink)
Oppie
Vista Home Basic, IE7
Had been using Acrobat reader 7 without any problems until this evening
(Widows updates installed this morning). I could open a PDF that was already
on my machine without problem but when trying to view a pdf from the web, I
get a couple of messages that it could not find external handler. A quick
work-around is to right click on the link and 'save target as' - then you
can manually open the file with acrobat 7.
Tried to reinstall Reader 7 without any improvement.
Uninstalled reader 7 and went to Adobe to get a fresh copy of the reader.
Hmmm, the only reader supported for Vista evidently is reader 8. With Vista,
it won't even let you try to get version 7.
Install reader 8 and all good again.
Acrobat reader 8 has a different look and feel that will take a bit of use
to get accustomed to (but then, so did Vista)
Installed updates listed in attachment.
Old 10-13-2007   #2 (permalink)
Andre Da Costa [ActiveWin]
Re: Acrobat Reader 7 problems
Might be security issues in version 7 that does meet the level of security
requirements in Vista why its not working. 8.1 is nice though, also works on
Vista x64.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
"Oppie" <oppie@xxxxxx> wrote in message
news:uBXlVEhDIHA.3716@xxxxxx
> already
> I
> Vista,
alternative to acrobat reader Vista General
Acrobat Reader v9.1 Software
problems with installing acrobat reader Vista file management
Adobe Acrobat Reader 8 Vista General
Problems Installing itunes, acrobat reader, quicktime... Vista installation & setup
