Vista - Vista not starting thanks to a.exe association problem... I think
Old 10-14-2007   #1 (permalink)
DJ_Anonymus
It started when I clicked on a .exe file to install something... it asked for
an application to open it with... after much thought I decided to take a risk
and go ahead, which turned out to be an unfortunate mistake. All my exe files
became associated with notepad (I laughed till I cried!) but I knew hot to
solve the problem from http://www.winhelponline.com/articles/165/1/
which suggested to delete the key. The problem was that I got a "unable to
delete... key in use" error and I decided to restart my comp in safe mode.
Good plan... except my computer didn't boot !
I really would like to retain my windows installation...
I was thinking if I could use another OS to access my Windows installation
and change the registry, I could get it up and running. The problem however
is that I cannot locate the required registry.
Any suggestions would be very much appreciated!!! Thank you in advance!
Old 10-14-2007   #2 (permalink)
DJ_Anonymus
clarifying
The key that's required to be deleted is
HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \
Explorer \ FileExts \ .exe \ UserChoice
The OS is Windows Vista Ultimate
I can use the WinVista Installation DVD to access my folder tree
Using Unbuntu (from a live cd) to type this thread!
Thanks again!
Old 10-14-2007   #3 (permalink)
Frank Saunders, MS-MVP IE
Re: Vista not starting thanks to a.exe association problem... I think
"DJ_Anonymus" <DJ_Anonymus@xxxxxx> wrote in message
news:E6447388-E9B8-4EBF-A3F0-0ABF029CE263@xxxxxx
> for
> risk
> files
> however
Click the Start Orb | All Programs | Accessories
Right click Command Prompt and choose Run as Administrator.
Type
regedit
and press Enter.
Frank Saunders, MS-MVP IE, OE/WM
I won't answer email.
Old 10-14-2007   #4 (permalink)
DJ_Anonymus
There's no start orb in WinVista Installation. This is Vista's installation
program. It loads from the DVD to a partition of the hard disk it labels as
X:\ and launches Vista Installation from there. I used the diagnostics to
launch a command prompt window and typed "start regedit" for the registry.
Problem is it acts like an OS by itself so the rgedit it loads is not the
same one as the one on my Windows installation. Do you have any idea where
the registry files for my Vista installation are located? I can open the
registry in notepad and change the values required.
P.S The istall program can run most of the basic windows stuff I think.
Thank you for the reply!
Old 10-14-2007   #5 (permalink)
bomb#20
DJ_Anonymus wrote:
> asked for an application to open it with... after much thought I
> decided to take a risk and go ahead, which turned out to be an
> unfortunate mistake. All my exe files became associated with notepad
> (I laughed till I cried!) but I knew hot to solve the problem from
> "unable to delete... key in use" error and I decided to restart my
> comp in safe mode. Good plan... except my computer didn't boot !
> installation and change the registry, I could get it up and running.
> The problem however is that I cannot locate the required registry.
> advance!
If you want to edit your registry I've upped an iso image of a BartPE disk with a registry editor on it.
http://www.megaupload.com/?d=S5PV3YHG
[72m/b]
You need to burn the image to a cd and boot from it.
When it is loaded there are a few boxes to tick:
Network support?=no
Go > Programs > Registry Editor
Select remote registry=c:\windows [normally]
Select default hives:
sam
security
software
system
Select remote user profile ? = yes
Browse to c:\users\YOURNAME\ntuser.dat
Select another user profile? = no
Your hive will be the last entry on the displayed list.
Then regedit will open and all Vista hives will be listed as _REMOTE.
So you navigate to HKEY_USERS_REMOTE_YOURNAME
and you should be in familiar territory.
Good luck !
Old 10-14-2007   #6 (permalink)
Paul Randall
"bomb#20" <darkstar@xxxxxx> wrote in message
news:WICdnTaSx8Alo4_aRVnyvgA@xxxxxx
>> advance!
> [72m/b]
> Network support?=no
> sam
> security
> software
> system
This looks like it could be very useful, and I realize it costs to have a
place to store big things like this on the web.
The download page looks scary.
I see two download buttons, but neither one seems associated with Filename:
pebuilder3.zipFilename: pebuilder3.zip
Filesize: 72.8 MB
When I hover over the download buttons, no text shows up in the status bar;
normally, the link to the item to be downloaded would show up. How do we
know that clicking these buttons won't install a bunch of crapware,
advertising, or other junk that messes up our browser toolbar or our
computer?
-Paul Randall
Old 10-14-2007   #7 (permalink)
bomb#20
>>> advance!
>> [72m/b]
>> Network support?=no
>> sam
>> security
>> software
>> system
> have a place to store big things like this on the web.
> Filename: pebuilder3.zipFilename: pebuilder3.zip
> Filesize: 72.8 MB
> status bar; normally, the link to the item to be downloaded would
> show up. How do we know that clicking these buttons won't install a
> bunch of crapware, advertising, or other junk that messes up our
> browser toolbar or our computer?
> -Paul Randall
It costs nothing to store files on the web.
It is stored with Megaupload.
It is a free account.
If you want to use the software I posted enter the 3 digits and download it.
If you are too scared to navigate a Megaupload page, Google " BartPE",
learn how to build your own Bart boot disk, with a reg editor plug-in, and use that.
Old 10-14-2007   #8 (permalink)
DJ_Anonymus
Hey Bomb! Thanks a lot! I'm sure I can use this to fix the registry! Can't
tell you how relieved I am!! Thanks a lot!
Old 10-14-2007   #9 (permalink)
bomb#20
DJ_Anonymus wrote:
> Can't tell you how relieved I am!! Thanks a lot!
If you use it, some of the start menu items are not included. It uses a default
menu which I forgot to edit when I made it.
The file manager (explorer-type thing) is loaded and obviously the registry editor.
Old 10-15-2007   #10 (permalink)
Paul Randall
news:BYydnTblwtQr-Y_anZ2dneKdnZydnZ2d@xxxxxx
>>>> advance!
>>> [72m/b]
>>> Network support?=no
>>> sam
>>> security
>>> software
>>> system
>> Filesize: 72.8 MB
>> -Paul Randall
> it.
> use that.
Thanks for the info. It downloaded faster than I thought it would. So far,
I've only gotten one unexpected web page - something like megamovie
competitor to YouTube.
I built a BartPE disk a year or two ago and used it for other things. I'll
be interested in seeing the difference with yours. I've downloaded WAIK but
haven't gotten around to building my own PE system yet.
Thanks for the info on Megaupload.
-Paul Randall
I have problem starting up Vista - problem with driver Drivers
Vista tiff file association problem Vista General
vista x64 file association problem General Discussion
vista business - problem setting file association for opera.exe Vista General
vista business-problem setting file association for opera.exe Vista General
