Vista - SOLUTION (kinda) for Control Panel, preferences & update.
Old 10-15-2007   #1 (permalink)
BarbLynne
O.K. I had a thread that said I was having problems with opening control
panel and preferences and windows update in VISTA.
Thanks to all of you for your help. Nothing worked. Here's what I did.
I went into "computer" then clicked on "control panel" on the LEFT pane.
It opened only in the left pane. I was able to access the preferences. I
was able to access "windows update" I updated.
This is not a solution to the problem, but you can at least get in somehow.
Try it.
I really hope Microsoft will find a fix for this problem. Please Microsoft
find a fix!
BarbLynne
In VISTA-Control Panel, MS Update, & others won't open. Vista General
Cant open Control Panel run windows update defender update Vista performance & maintenance
problems with windows vista solution center in control panel Vista General
Control Panel, Windows Update Fail sometimes... Vista performance & maintenance
cant update, enter control panel or problems and solutions.. please help me Vista General
