1.    17 Oct 2007 #1
    nunamoose Guest
    TASK SCHEDULER ENGINE has stopped working.... ????
    In the last few days, when this Core Duo Vista Home Premium
    laptop boots, or even comes out of hibernation, I'll often see a
    box that says something close to:
    TASK SCHEDULER ENGINE HAS STOPPED WORKING
    Windows will try to find a solution
    I click, it goes away, and I don't miss anything. Overall, the
    transition to Vista has been quite painless and comfortable, but
    this is annoying.
    What's going on?
    Thanks!
  2.    07 Jan 2008 #2
    Nanrn Guest
    RE: TASK SCHEDULER ENGINE has stopped working.... ????
    > this is annoying.
    > What's going on?
    > Thanks!
  3.    07 Jan 2008 #3
    Nanrn Guest
    I'm having the same problem. Whenever I boot up my computer, I get the
    message that Task scheduler engine has stopped working and that windows is
    working to find a solution! Any suggestions would be great!
    > this is annoying.
    > What's going on?
    > Thanks!
  4.    08 Jan 2008 #4
    Sharon Guest
    I'm having this problem too. Is there a solution for it please? The box is
    constantly coming up on my screen and I'm really having problems accessing
    any software applications.
    > this is annoying.
    > What's going on?
    > Thanks!
  5.    20 Jan 2008 #5
    zachd [MSFT] Guest
    Re: TASK SCHEDULER ENGINE has stopped working.... ????
    What's the specific fault data for this crash according to the Problem
    Reports and Solutions center:
    http://zachd.com/pss/pss.html#bucket
    Speaking for myself only.
    See http://zachd.com/pss/pss.html for some helpful WMP info.
    "Nanrn" <Nanrn@xxxxxx> wrote in message
    news:42D6D966-07FD-4061-9C9D-571775D2E486@xxxxxx
    >> this is annoying.
    >> What's going on?
    >> Thanks!
Task Scheduler engine has stopped working??
for months now this pop-up has been appearing every 5min or so and i really dont know how to fix it. here's the signature: Problem signature: ...
General Discussion
task scheduler stopped working
Am getting a warning box on startup: Task Scheduler has stopped working When I try to start the program directly I get Error )x8000FFF. The process...
Vista performance & maintenance
Task Scheduler stopped working altogether?
I've been using task scheduler ever since i had Vista - apart from some peculiarities (have to reset the task if i reset the PC) it always worked ...
Vista General
task scheduler engine not working
This message appears on every boot. Is there a way to identify the problem and cure it?
task scheduler engine pop up message
keep getting a pop up message "task scheduler engine stopped working and was closed" What does it mean and how can it be rectified and the pop up...
Task Scheduler Engine hogging cpu/locking laptop
My husband has a Dell XPS that was pre-loaded with Vista Home Premium. He has had no problems to speak of with Vista to this point, but is on a...
Vista General
Task Scheduler Engine won't end
I'm using Vista Home Premium. Whenever I attempt to shutdown or logout this message appears: "The following programs are still running. TaskEng -...
Vista installation & setup
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
