Vista - USB 2.0 flash drive
Old 10-19-2007   #1 (permalink)
Scott
USB 2.0 flash drive
I just purchased a new PQI USB 2.0 flash drive and inserted into the USB
port of my HP Pavilion PC running on Vista Home Premium. The system cannot
reconise it and asks for driver. The drive states Windows Vista compatible.
I insert it to other XP pcs and Vista pc and all work correctly without any
need of driver. With other USB 2.0 flash drives, they work correctly. It
seems to me the Vista on my pc does not work correctly. Can someone advise
the possible reasons and fixes.
Thanks,
Scott
Old 10-19-2007   #2 (permalink)
Andre Da Costa[ActiveWin]
Re: USB 2.0 flash drive
Did it come with U3 software? That could possibly be the cause. Open Device
Manager and scan for hardware changes. I would return it to the place of
purchase and get something that is know to work, I use SanDisk Cruzer Micro
2.0 GB Enhanced for Readyboost.
Andre
Blog: http://adacosta.spaces.live.com
My Vista Quickstart Guide:
http://adacosta.spaces.live.com/blog...3DB!9709.entry
"Scott" <NoSpam-Scott.Xe@xxxxxx> wrote in message
news:%23RyRwklEIHA.5980@xxxxxx
>compatible. I insert it to other XP pcs and Vista pc and all work correctly
>without any need of driver. With other USB 2.0 flash drives, they work
>correctly. It seems to me the Vista on my pc does not work correctly. Can
>someone advise the possible reasons and fixes.
> Thanks,
> Scott
Old 10-19-2007   #3 (permalink)
JW
If it came with U3 software then then try use your XP system to reformat the
entire drive in Fat32 format and then try it on your Vista System.
Also suggest that you get the hot fix described in the following link:
http://support.microsoft.com/default...en-us%3b936003
"Andre Da Costa[ActiveWin]" <andred25@xxxxxx> wrote in message
news:erfB4rlEIHA.280@xxxxxx
> Device Manager and scan for hardware changes. I would return it to the
> place of purchase and get something that is know to work, I use SanDisk
> Cruzer Micro 2.0 GB Enhanced for Readyboost.
> Andre
>>cannot reconise it and asks for driver. The drive states Windows Vista
>>correctly without any need of driver. With other USB 2.0 flash drives,
>>they work correctly. It seems to me the Vista on my pc does not work
>>correctly. Can someone advise the possible reasons and fixes.
>> Thanks,
>> Scott
Old 10-19-2007   #4 (permalink)
Scott
Andre,
What is U3 software? The drive does not come with any driver. The system
reconises the drive name, Intelligent, pqi IntelligentStick USB Device but
seems does not work with my computer. It seems my OS is missing something
but other Vista system works ok. Very strange on my HP computer and would
like to call at HP service centre for help.
Scott
"Andre Da Costa[ActiveWin]" <andred25@xxxxxx> ¦b¶l¥ó
news:erfB4rlEIHA.280@xxxxxx ¤¤¼¶¼g...
> Andre
>> Thanks,
>> Scott
Old 10-19-2007   #5 (permalink)
U3 is a software that comes bundled with lots Thumb drives lately. Its used
to securely synchronize yout files and access on any PC.
I would follow JWs direction and formation the drive on an XP based system
then try connecting it to Vista.
Andre
news:uoM4ZDmEIHA.1208@xxxxxx
Quote:
> Andre,
> Scott
>> Andre
>>> Thanks,
>>> Scott
Old 10-19-2007   #6 (permalink)
Scott
Hello JW,
Thanks for your advice. The drive does not come with any software. The
software needs to download from their website but those relate to
password-protected pc, encrypt file. I tried to format the entire drive in
Fat32 in a pc running Windows XP. It does not help the issue.
I checked your suggested link that fixes to the USB device after hiberation.
My issue seems related to drive reconginiation, not hiberation. I guess the
drivers in Vista OS does not have one for my drive while XP has. This is
not my first time to encounter this issue and my last time it happened on a
flash drive that I bought before Vista luanched. It works on many pcs of
Windows XP without any problem. It seems illogical but it leads the
customers to think in this direction.
Regards,
Scott
"JW" <JW@xxxxxx> 在郵件
news:0C1731EE-9FDD-477C-BE6E-48578E78E1AE@xxxxxx ä¸*撰寫...
> the entire drive in Fat32 format and then try it on your Vista System.
>> Andre
>>> Thanks,
>>> Scott
Old 10-19-2007   #7 (permalink)
Scott
Andre,
Thanks for your reply. After launched Vista, I purchased two new flash
drives and both do not have U3 software. Can the C3 software be found on
Microsoft website? All the users of flash drive strongly believe the flash
drive does not need driver since Windows 2000. Obviously, it is not true??
Regards,
Scott
news:OuDUpNmEIHA.4752@xxxxxx ¤¤¼¶¼g...
> used to securely synchronize yout files and access on any PC.
> Andre
Quote:
>> Andre,
>> system reconises the drive name, Intelligent, pqi IntelligentStick USB
>> Device but seems does not work with my computer. It seems my OS is
>> missing something but other Vista system works ok. Very strange on my HP
>> computer and would like to call at HP service centre for help.
>> Scott
>>> Andre
>>>> Thanks,
>>>> Scott
Old 10-20-2007   #8 (permalink)
U3 is a third party software that is distributed by U3, visit
http://www.u3.com for more information. Windows Vista supports Thumbdrives
out of the box, for older versions of Windows, you might need software to
make it communicate the OS, Windows 2000 I believe does not need a driver.
Andre
news:uRUCmvsEIHA.1208@xxxxxx
Quote:
> Andre,
> flash drive does not need driver since Windows 2000. Obviously, it is not
> true??
> Regards,
> Scott
>> system then try connecting it to Vista.
>> Andre
Quote:
>>> Andre,
>>> HP computer and would like to call at HP service centre for help.
>>> Scott
>>>> Andre
>>>>>USB port of my HP Pavilion PC running on Vista Home Premium. The
>>>>>system cannot reconise it and asks for driver. The drive states
>>>>>Windows Vista compatible. I insert it to other XP pcs and Vista pc and
>>>>>all work correctly without any need of driver. With other USB 2.0
>>>>>flash drives, they work correctly. It seems to me the Vista on my pc
>>>>>does not work correctly. Can someone advise the possible reasons and
>>>>>fixes.
>>>>> Thanks,
>>>>> Scott
Old 10-20-2007   #9 (permalink)
JW
The hotfix fixes a lot of other USB problems besides problems related to
Hibernation I suggest again that you try it.
news:eTTxtrsEIHA.4752@xxxxxx
Quote:
> Hello JW,
> in Fat32 in a pc running Windows XP. It does not help the issue.
> hiberation. My issue seems related to drive reconginiation, not
> hiberation. I guess the drivers in Vista OS does not have one for my
> drive while XP has. This is not my first time to encounter this issue and
> my last time it happened on a flash drive that I bought before Vista
> luanched. It works on many pcs of Windows XP without any problem. It
> seems illogical but it leads the customers to think in this direction.
> Regards,
> Scott
>>> Andre
>>>> Thanks,
>>>> Scott
Old 10-20-2007   #10 (permalink)
MICHAEL
Actually, this is the newest update for USB core components;
http://support.microsoft.com/kb/941600
Cumulative update rollup for USB core components in Windows Vista
October 2, 2007
This article describes an update rollup that resolves some reliability issues in the USB core
components in Windows Vista. You will achieve better reliability in various scenarios by
installing this update.
-Michael
* JW:
Quote:
> If it came with U3 software then then try use your XP system to reformat the entire drive in
Quote:
>> Did it come with U3 software? That could possibly be the cause. Open Device Manager and
>> scan for hardware changes. I would return it to the place of purchase and get something
>> that is know to work, I use SanDisk Cruzer Micro 2.0 GB Enhanced for Readyboost. -- Andre
>> Blog: http://adacosta.spaces.live.com My Vista Quickstart Guide:
>> http://adacosta.spaces.live.com/blog...3DB!9709.entry "Scott"
Quote:
>>> I just purchased a new PQI USB 2.0 flash drive and inserted into the USB port of my HP
>>> Pavilion PC running on Vista Home Premium. The system cannot reconise it and asks for
>>> driver. The drive states Windows Vista compatible. I insert it to other XP pcs and
>>> Vista pc and all work correctly without any need of driver. With other USB 2.0 flash
>>> drives, they work correctly. It seems to me the Vista on my pc does not work correctly.
>>> Thanks,
>>> Scott
Ready Boost Flash Drive 4 gb from 8 gb Drive Vista hardware & devices
Flash Drive has no drive letter... Not in Disk Management Vista hardware & devices
External Hard Drive vs Flash Drive Virtual PC
Pen drive/USB flash drive showing as floppy disk Vista General
LastWriteTime and Locating the drive letter of a flash drive. PowerShell
