Vista Tutorial - Wireless Adapter is preventing vista from booting!! Help
Old 10-19-2007   #1 (permalink)
WolfRedeemed
Guest
Hey all,
I have a Dlink Dwl-G520(B) adapter installed with vista 64 and had this card
working fine before I updated windows when i first connected to the internet.
now the system wont boot into vista at all unless i go through safe mode
disable the card and reboot then enable it in windows (have to do this every
time). It works fine when in windows (although i cant connect to a hidden
ssid).
Would any body be able to help? cause it affects the experience of vista and
a new comp.
Thanks in advance
Old 10-20-2007   #2 (permalink)
Barb Bowman
Guest
Re: Wireless Adapter is preventing vista from booting!! Help
Before you updated windows? Exactly what update are you referring
to? Windows Update installed something that impacted behavior?
Uninstall it or uninstall the last set of updates and test to see if
things work. Then reinstall them manually one at a time to see which
one breaks things.
On Fri, 19 Oct 2007 19:51:00 -0700, WolfRedeemed
<WolfRedeemed@xxxxxx> wrote:
Quote:
>Hey all,
>ssid).
>a new comp.
>Thanks in advance
Barb Bowman
MS Windows-MVP
http://www.microsoft.com/windowsxp/e...ts/bowman.mspx
http://blogs.digitalmediaphile.com/barb/
Vista Supported Wireless USB Adapter / Wireless PCI Card Vista General
Preventing Hackers on my Wireless Network Network & Sharing
USB Wireless Adapter in Vista SP1 Vista networking & sharing
USB Liksys wireless adapter - preventing boot Vista hardware & devices
Preventing connection to a wireless network Vista networking & sharing
