Vista - Kodak USB Picture Card Reader driver for XP SP2 does not work
Old 07-07-2006   #1 (permalink)
=?Utf-8?B?Q29wZW5oYWdlbg==?=
Tried to install Kodak USB Picture card Reader with it's driver for XP SP2
and it does not work. After installation (which hangs at reboot) the system
says that is not recognozed and that it has malfunctioned. The help offered
is that I should try to reconnect and that if that doesn't work I should
replace the unit!!It worked fine on XP SP2 .
I can see from the light diode that it is reader the CF card but there is
apparently no contact with Windows Explorer.
Old 07-08-2006   #2 (permalink)
=?Utf-8?B?Sm9udHk=?=
RE: Kodak USB Picture Card Reader driver for XP SP2 does not work
Bet it is USB 1.1. It is not supported in Vista. Need USB 2 gear.
Jonty
Old 07-08-2006   #3 (permalink)
Mark D. VandenBerg
Re: Kodak USB Picture Card Reader driver for XP SP2 does not work
This is good information to know.
Mark
Keeping the fun in dysfunctional!
"Jonty" <Jonty@discussions.microsoft.com> wrote in message
news:FF15DBB7-3F19-4498-89B7-0CF5DD1C9063@microsoft.com...
> Jonty
>> SP2
>> system
>> offered
have to restart for card reader to work again? General Discussion
media card reader wont work now Drivers
Smart Card Reader will not work with Vista. Vista hardware & devices
I Can't Install an Olympus Camera or a Kodak Card Reader Vista hardware & devices
Card reader does not work in Vista Vista hardware & devices
