| | How to test USB speed / performance Hello, Does anyone out there know how I can test the speed of my USB ports without buying hardware? Is there any software out there to do this (hopefully free)? Thanks in advance! |
| | Re: How to test USB speed / performance What does it matter, it's likely either 2.0 or 1.1. If you have enhanced in the Device Manager, it's 2.0 iBizTalk wrote: Quote: > Hello, > > Does anyone out there know how I can test the speed of my USB ports > without buying hardware? Is there any software out there to do this > (hopefully free)? > > Thanks in advance! |
| | Re: How to test USB speed / performance iBizTalk wrote: Quote: > Hello, > > Does anyone out there know how I can test the speed of my USB ports > without buying hardware? Is there any software out there to do this > (hopefully free)? > > Thanks in advance! http://www.passmark.com/products/usb2loopback.htm Paul |
| | Re: How to test USB speed / performance Unless Bob they are using older USB cabling? -- Regards. Gerry ~~~~ FCA Stourport, England Enquire, plan and execute ~~~~~~~~~~~~~~~~~~~ Bob I wrote: Quote: > What does it matter, it's likely either 2.0 or 1.1. If you have > enhanced in the Device Manager, it's 2.0 > > iBizTalk wrote: > Quote: >> Hello, >> >> Does anyone out there know how I can test the speed of my USB ports >> without buying hardware? Is there any software out there to do this >> (hopefully free)? >> >> Thanks in advance! |
| | Re: How to test USB speed / performance Then plugging in a 2.0 device will tell him, but without ANY hardware? Saint Happening is the patron there. Gerry wrote: Quote: > Unless Bob they are using older USB cabling? > |
| Test Speed | Network & Sharing | |||
| Restart Speed Test | Chillout Room | |||
| Speed test confirm...Vista is faster than XP...! | Vista General | |||
| ReadyBoost, Speed up your PC’s performance | Vista General | |||
| XP vs Vista Speed Test | Vista General | |||
