Vista - No sound after sleep mode.
Old 11-01-2007   #1 (permalink)
Hans
Before going into sleep mode the sound works fine. After exiting sleep mode I
have no sound anymore. The computer is delivered with Vista and it has
happened to two identical computers (laptop) so I doubt it is hardware
failure.
Any ideas??
Old 11-22-2007   #2 (permalink)
S a r a t h
Re: No sound after sleep mode.
> failure.
> Any ideas??
Update this hotfix
http://support.microsoft.com/kb/937077/
Old 12-11-2007   #3 (permalink)
Joe
I am having a similar problem. My computer was working like a charm and
suddenly, one night it started to fail. After putting my computer to sleep
then I still have sound but a very annoying very low resolution sound.
Everything sounds terrible. I have not tried yet the patches but this is very
weird to the point I am not using the sleep function any more.
Once I restart my computer, then the sounds get back to its normal 'state'.
Any ideas aside from the so mentioned patches???
ASUS M2NPV-VM integrated HD Sound (6 channels) --> all drivers up to date.
> > failure.
> > Any ideas??
> Update this hotfix
Old 12-11-2007   #4 (permalink)
Joe
> > failure.
> > Any ideas??
> Update this hotfix
No sound after resuming from sleep mode Sound & Audio
No sound after sleep mode Vista General
Resume from Sleep mode, and no sound? Vista General
Sleep Mode & No Sound? Vista General
No Sound after sleep mode Vista General
