| | ZTE MODEM INSTALLTION PROBLEM i have an acer aspire 4710z laptop with vista loaded on to it i am trying to install a ZTE mg880 usb modem on to it. when i insert the zte installation cd and run the setup., before the setup is completed., i get a message box saying "installer.exe has stopped working" what do i do? how do i go abt installing zte? |
| | Re: ZTE MODEM INSTALLTION PROBLEM "satish" <satish@xxxxxx> wrote in message news:FE009BC6-E4DF-4D54-85CF-690190110476@xxxxxx Quote: >i have an acer aspire 4710z laptop with vista loaded on to it > i am trying to install a ZTE mg880 usb modem on to it. > when i insert the zte installation cd and run the setup., before the setup > is completed., i get a message box saying "installer.exe has stopped > working" > what do i do? > how do i go abt installing zte? > installation CD has Vista drivers on it? Have you tried right-clicking the installer file on the CD and choosing "run as administrator"? I'd suggest checking either the vendor or manufacturer tech support for updated drivers or solutions to your installation problem. |
| | Re: ZTE MODEM INSTALLTION PROBLEM Are the drivers on the CD VISTA drivers? Have you been to the modem manufacturer's web site to see if they have updated Vista drivers? Also, take care to note if the modem's USB cable should be unplugged before you install the drivers and plugged in only after the driver install or when prompted to plug in the USB cable during the driver install. I Bleed Blue and Gold GO BEARS! "satish" <satish@xxxxxx> wrote in message news:FE009BC6-E4DF-4D54-85CF-690190110476@xxxxxx Quote: >i have an acer aspire 4710z laptop with vista loaded on to it > i am trying to install a ZTE mg880 usb modem on to it. > when i insert the zte installation cd and run the setup., before the setup > is completed., i get a message box saying "installer.exe has stopped working" > what do i do? > how do i go abt installing zte? > |
| | Re: ZTE MODEM INSTALLTION PROBLEM Thanx for the response call bear 66 The drivers are vista drivers "as stated by the manufacturers" and i did not plug in the usb modem before installing the drivers. but the response is as stated in my previous mail. U have Any other solution? "Cal Bear '66" wrote: Quote: > Are the drivers on the CD VISTA drivers? > > Have you been to the modem manufacturer's web site to see if they have updated > Vista drivers? > > Also, take care to note if the modem's USB cable should be unplugged before you > install the drivers and plugged in only after the driver install or when > prompted to plug in the USB cable during the driver install. > > > I Bleed Blue and Gold > GO BEARS! > > > "satish" <satish@xxxxxx> wrote in message > news:FE009BC6-E4DF-4D54-85CF-690190110476@xxxxxx Quote: > >i have an acer aspire 4710z laptop with vista loaded on to it > > i am trying to install a ZTE mg880 usb modem on to it. > > when i insert the zte installation cd and run the setup., before the setup > > is completed., i get a message box saying "installer.exe has stopped working" > > what do i do? > > how do i go abt installing zte? > > > |
| | Re: ZTE MODEM INSTALLTION PROBLEM Thanx for the response pvdg42 i am referring to reliance usb data card zte mg880 As per the manufacturers the drivers are for vista i have already tried installing the drivers as "run as administrator" but the problem repeats i have already reported the prob. to reliance tech centre ( so called help centre) and am waiting for a response from them for the past 3 days. Do u have any other solution? "PvdG42" wrote: Quote: > "satish" <satish@xxxxxx> wrote in message > news:FE009BC6-E4DF-4D54-85CF-690190110476@xxxxxx Quote: > >i have an acer aspire 4710z laptop with vista loaded on to it > > i am trying to install a ZTE mg880 usb modem on to it. > > when i insert the zte installation cd and run the setup., before the setup > > is completed., i get a message box saying "installer.exe has stopped > > working" > > what do i do? > > how do i go abt installing zte? > > > Are you referring to the Reliance Mobile ZTE MG880? Are you sure the > installation CD has Vista drivers on it? > Have you tried right-clicking the installer file on the CD and choosing "run > as administrator"? > I'd suggest checking either the vendor or manufacturer tech support for > updated drivers or solutions to your installation problem. > > |
| | #6 (permalink) |
| | Re: ZTE MODEM INSTALLTION PROBLEM Thanx PvdG42 for the response i am referring to reliance usb data card zte mg880 i have already tried running the drivers as " run as administrator" but the response is the same i have also reported the problem to reliance tech support " help centre" and am waiting for their response for the past 3 days do u have any other solution? "PvdG42" wrote: Quote: > "satish" <satish@xxxxxx> wrote in message > news:FE009BC6-E4DF-4D54-85CF-690190110476@xxxxxx Quote: > >i have an acer aspire 4710z laptop with vista loaded on to it > > i am trying to install a ZTE mg880 usb modem on to it. > > when i insert the zte installation cd and run the setup., before the setup > > is completed., i get a message box saying "installer.exe has stopped > > working" > > what do i do? > > how do i go abt installing zte? > > > Are you referring to the Reliance Mobile ZTE MG880? Are you sure the > installation CD has Vista drivers on it? > Have you tried right-clicking the installer file on the CD and choosing "run > as administrator"? > I'd suggest checking either the vendor or manufacturer tech support for > updated drivers or solutions to your installation problem. > > |
| | #7 (permalink) |
| | Re: ZTE MODEM INSTALLTION PROBLEM Hey guys... cool down... do one thing.. just go the device manager after installation is complete ( I know it will show error)..look under the phone and modem options...there will be three uninstalled Data interface.. just right click on them and select update drivers.. then browse and go to the drivers folder in the installation CD..from there choose vista folder and then select the options xp96 or something...not the amd one... then give a go ahead.. you installation will complete and you will be able to access net... I don't know why the heck a company like reliance cannot provide its customers with the correct drivers... Thats all ! -- pallabbarua ------------------------------------------------------------------------ pallabbarua's Profile: http://forums.techarena.in/members/pallabbarua.htm View this thread: http://forums.techarena.in/vista-har...ces/845836.htm http://forums.techarena.in |
| | #8 (permalink) |
| | Re: ZTE MODEM INSTALLTION PROBLEM hi, we have installed the ZTE MG880 modem, but it connects only for a few seconds then it disconnects automatically, then it again connects and disconnects. wat is the problem can anybody give me a solution -- smartguy_eddy ------------------------------------------------------------------------ smartguy_eddy's Profile: http://forums.techarena.in/members/smartguy_eddy.htm View this thread: http://forums.techarena.in/vista-har...ces/845836.htm http://forums.techarena.in |
| | #9 (permalink) |
| | Re: ZTE MODEM INSTALLTION PROBLEM smartguy_eddy <smartguy_eddy.3iwczd@xxxxxx> wrote: Quote: >hi, we have installed the ZTE MG880 modem, but it connects only for a >few seconds then it disconnects automatically, then it again connects >and disconnects. > >wat is the problem can anybody give me a solution problem. A LOT more. |
| | #10 (permalink) |
| Vista Ultimate x64 | Re: ZTE MODEM INSTALLTION PROBLEM im also having the same problem with my modem. everytime i try to connect it tells me to insert the device but the deive will be in correct spot. how do i go on about it. im using vista ultimate. |
| Hello i need installtion help :p | Graphic cards | |||
| Installtion Error. | Vista installation & setup | |||
| ECS KN1 with Radeon 1600 Pro installtion failure | Vista installation & setup | |||
| Installtion trouble--Autorun.dll | Vista General | |||
| installtion error 0x00000e9 | Vista installation & setup | |||
