| | Creative Sound Blaster X-Fi Problem. Hi all, About two weeks ago my Creative SoundBlaster X-Fi XtremeMusic running under Vista Ultimate for almost 12 months suddenly started to make strange noises and appears to get "stuck" when playing World of Warcraft. It is possible that this is happening with other applications too, but I haven't noticed it. I tried installing a couple of different Vista drivers for the card, (which was using an XP driver) but unfortunately now the driver either does not work, or I get an error message telling me that the device can't start. I now have no sound at all. It is a Dell PC. I phoned Dell today only to be told to format the hard drive & install the original operating system (Windows XP Media Center). That seems a little radical, especially since the card has been working under Vista for so long. Video card model number is SB0460, if this helps. Does anyone have a Vista driver for this card or know how I can rectify the problem. It is very annoying. Thanks in advance, Dave. |
| | Re: Creative Sound Blaster X-Fi Problem. See http://forums.creative.com/creativel...board.id=Vista and you will see that many are having problems with X-Fi Creative drivers. Uninstall all Creative applications in Uninstall or change a progam. Then in Device Manager Uninstall the X-Fi device and tick the option to remove the drivers. Reboot, as you will be required to do, then close all applications, including any in the system tray, especially antivirus and install the driver of your choice. I found the 2.15.0002 the most stable,but it took some work to get it properly established, usually I had to uninstall it (not deleting the drivers) and then re-install it after each boot. Once established I used Sleep to preserve the driver state. Currently, I am using the latest 2.15.0004 which loads correctly but often becomes unusable. Deleting the device when it has become unusable and then rebooting and letting the driver be installed creates a stable system for me. "Dave" <dbarrat@xxxxxx> wrote in message news:3FCECC19-DA5A-4B5B-8AAC-A93CB8570AAF@xxxxxx Quote: > Hi all, > > About two weeks ago my Creative SoundBlaster X-Fi XtremeMusic running > under Vista Ultimate for almost 12 months suddenly started to make strange > noises and appears to get "stuck" when playing World of Warcraft. It is > possible that this is happening with other applications too, but I haven't > noticed it. I tried installing a couple of different Vista drivers for the > card, (which was using an XP driver) but unfortunately now the driver > either does not work, or I get an error message telling me that the device > can't start. I now have no sound at all. It is a Dell PC. I phoned Dell > today only to be told to format the hard drive & install the original > operating system (Windows XP Media Center). That seems a little radical, > especially since the card has been working under Vista for so long. Video > card model number is SB0460, if this helps. > > Does anyone have a Vista driver for this card or know how I can rectify > the problem. It is very annoying. > > Thanks in advance, Dave. |
| Creative Sound Blaster X-Fi Fatal1ty | Vista General | |||
| creative sound blaster 5.1 | Vista hardware & devices | |||
| Creative sound blaster live! value | Drivers | |||
| Creative Sound Blaster Live! | Vista hardware & devices | |||
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Vista General | |||
