Driver Errors & Hot Fix Malfunction
  1. #1
    Vague NYC Guest
    hello, like several others i have been having problems getting Vista to
    acknowledge or install USB devices. i'm asked to locate the drivers for my
    devices and even when i do vista won't accept them.
    i've downloaded all the vista updates for my products from their respective
    websites and still vista won't recognize any of them.
    a Microsoft update pop up window directed me to their Hot Fix page stating
    that they acknowledge there are driver recognition issues with Vista and the
    hot fix should work for the specified problem. microsoft sent me the link, i
    downloaded it and tried to run it on my laptop but the exe asks for
    additional volumes as it is a "multidisk" installation. i e-mailed microsoft
    asking them for the additional links or volumes to their hot fix and they
    have been of no help at all asking me to contact the manufacturer of my
    laptop (toshiba) who of course in turn told me the problem isn't their
    responsibility and that i should contact the 3rd party manufacturers who have
    already provided me with driver updates that windows vista still won't
    recognize.
    i've spent several grand on a new laptop and musical equipment none of which
    i can use as long as these driver and compatibility issues with vista cont.
    is there any help at all? suggestions, work arounds or downloads?
    thanks for any help offered.
  2. #2
    Elliott Guest
    RE: Driver Errors & Hot Fix Malfunction
    I had a similar problem and ran an upgrade using my original Vista disk. Then
    I gor a Code 12 on the standard OpenHCD USB controller. Here a link to others
    who have the same problem, we're trying to find a solution too:
    http://windowshelp.microsoft.com/com...1-3642721fd1c6
    Since you just purchased your machine, you can email support directly and
    give them this link. With this many people experiencing the same problem,
    maybe we can get a resolution.
    Thanks
    > recognize.
  3. #3
    Elliott Guest
    Solution by LG
    See:
    http://windowshelp.microsoft.com/com...ces&sloc=en-us
    > recognize.
Driver Errors & Hot Fix Malfunction problems?
Errors w/ User-mode Driver Framework Host Process mzpete Drivers 0 03 Jun 2009
svchost.exe_Net Driver HPZ12 errors RayS Vista print fax & scan 0 30 May 2008
Vista SP1 Print Driver Errors Ken M. Vista print fax & scan 4 22 May 2008
Errors at the print que on Vista Home... New driver install, HELP! metadog Vista General 0 14 Mar 2008
HP Business Inkjet 1000 driver malfunction Viv Vista print fax & scan 8 05 Feb 2008
