| | ups battery systems-- in vista ultimate, when system boots, and i look at taskmanager, i see that mainserve (the battery software) is using 60% of cpu cycles and 30 %of memory can't figure out why i find myself shutting off the connection between the battery and the system to reduce cpu load ..running vista ultimate, 1.6 ghz athalon, 1.5 gig memory (help) -- dandy richardson |
| | Re: ups battery systems-- Driver issue? Did you install software or did Vista ask to find a driver? Make/model of UPS? I doubt 3rd party is needed, at least with APC and probably most more popular brands. "ultimate d rich" <ultimatedrich@xxxxxx> wrote in message news:B92604F5-6428-42DA-A892-55AD3476AC32@xxxxxx Quote: > in vista ultimate, when system boots, and i look at taskmanager, i see > that > mainserve (the battery software) is using 60% of cpu cycles and 30 %of > memory > can't figure out why i find myself shutting off the connection between > the > battery and the system to reduce cpu load ..running vista ultimate, 1.6 > ghz > athalon, 1.5 gig memory (help) > -- > dandy richardson |
| | Re: ups battery systems-- For Vista a vender supplied driver/application is often required if the interface is Serial, Vista dropped Serial UPS support. Michael "Rabbit" <white.rabbitt@xxxxxx> wrote in message news:C17A8655-E95C-44CA-A462-7B41C332D8B2@xxxxxx Quote: > Driver issue? Did you install software or did Vista ask to find a driver? > Make/model of UPS? > > > I doubt 3rd party is needed, at least with APC and probably most more > popular brands. > > > "ultimate d rich" <ultimatedrich@xxxxxx> wrote in > message news:B92604F5-6428-42DA-A892-55AD3476AC32@xxxxxx Quote: >> in vista ultimate, when system boots, and i look at taskmanager, i see >> that >> mainserve (the battery software) is using 60% of cpu cycles and 30 %of >> memory >> can't figure out why i find myself shutting off the connection between >> the >> battery and the system to reduce cpu load ..running vista ultimate, 1.6 >> ghz >> athalon, 1.5 gig memory (help) >> -- >> dandy richardson |
| | Re: ups battery systems-- we're talking about an apc ups xs1200 with (vista)drivers signed by ms..usb cable connection -- dandy richardson "Rabbit" wrote: Quote: > Driver issue? Did you install software or did Vista ask to find a driver? > Make/model of UPS? > > > I doubt 3rd party is needed, at least with APC and probably most more > popular brands. > > > "ultimate d rich" <ultimatedrich@xxxxxx> wrote in message > news:B92604F5-6428-42DA-A892-55AD3476AC32@xxxxxx Quote: > > in vista ultimate, when system boots, and i look at taskmanager, i see > > that > > mainserve (the battery software) is using 60% of cpu cycles and 30 %of > > memory > > can't figure out why i find myself shutting off the connection between > > the > > battery and the system to reduce cpu load ..running vista ultimate, 1.6 > > ghz > > athalon, 1.5 gig memory (help) > > -- > > dandy richardson |
| | Re: ups battery systems-- You could try the open source APC drivers http://www.apcupsd.org/ I find they work much better than the APC supplied ones and support a serial UPS on 32bit and 64bit Vista Peter Lawton "ultimate d rich" <ultimatedrich@xxxxxx> wrote in message news:A8388E4E-041B-44B7-B015-24C535C8E9A2@xxxxxx Quote: > we're talking about an apc ups xs1200 with (vista)drivers signed by > ms..usb > cable connection > -- > dandy richardson > > > "Rabbit" wrote: > Quote: >> Driver issue? Did you install software or did Vista ask to find a driver? >> Make/model of UPS? >> >> >> I doubt 3rd party is needed, at least with APC and probably most more >> popular brands. >> >> >> "ultimate d rich" <ultimatedrich@xxxxxx> wrote in >> message >> news:B92604F5-6428-42DA-A892-55AD3476AC32@xxxxxx Quote: >> > in vista ultimate, when system boots, and i look at taskmanager, i see >> > that >> > mainserve (the battery software) is using 60% of cpu cycles and 30 %of >> > memory >> > can't figure out why i find myself shutting off the connection between >> > the >> > battery and the system to reduce cpu load ..running vista ultimate, >> > 1.6 >> > ghz >> > athalon, 1.5 gig memory (help) >> > -- >> > dandy richardson |
| All sYstEmS go | Vista music pictures video | |||
| Using three 2.1 systems? | Sound & Audio | |||
| Laptop battery issue ??battery calibration?? | General Discussion | |||
| old/new systems can't see each other | Vista General | |||
| POS SYSTEMS | Vista General | |||
