I need advice on how to get vista to put a driver on for my ethernet card- please help
  1. #1
    robin Guest
    installed vista beta 2 on a clean formated HD. Everything installed fine
    but my ethernet card is on the mother board and for some reason it sees the
    new hardware but will not install a driver for it so I cannot even go to the
    web to find an update.
    What I do not understand is after trying 4 different ethernet cards with
    floppys that had drivers on them, vista would not see this either. (drivers
    are for win98-2000)
    I totally gave up, reformatted the HD and put on xp pro and xp pro found
    drivers for the original card on the mother board. Why can't vista find
    them.?
    Someone told me to try doing an upgrade from xp pro instead of a reformat-
    before i go and do this do you think this will work? or you have another
    suggestion for me to get vista to install a driver for the card?
    robin
  2. #2
    Mark D. VandenBerg Guest
    Re: I need advice on how to get vista to put a driver on for my ethernet card- please help
    While XP was an evolutionary redo of Win2000, Vista is a completely new
    operating system. As such, many things, including drivers, are handled
    differently. Simply put, just because it works in XP, doesn't mean it works
    in Vista.
    I suggest contacting the vendors of your NIC's to see if they have
    Vista-compatible drivers for their products, or, if they don't, search this
    newsgroup to see which NIC's have been able to work and then get one of
    them. Most are relatively inexpensive.
    Mark
    Keeping the fun in dysfunctional!
    "robin" <robinbk9_nospam@msn.com> wrote in message
    news:u27AXXPpGHA.4216@TK2MSFTNGP04.phx.gbl...
    > the
    > the
    > (drivers
    > are for win98-2000)
    > them.?
    > robin
  3. #3
    MICHAEL Guest
    I thought Vista was an "evolutionary redo" of
    Windows Server 2003 SP1.
    The Vista code was originally based on XP and
    that changed in late 2004.
    Windows Server 2003 has a different
    code base than XP.
    Longhorn Server and Vista share
    the same code base.
    http://www.winsupersite.com/faq/vista.asp
    Future Windows versions will always be based on the most up-to-date Windows version at the
    time, and today that version is Windows Server 2003 with Service Pack 1 (SP1). When Windows
    Vista development started two years ago, however, it was originally based on Windows XP. In
    mid-2004, Microsoft had to restart the core development of Windows Vista because it was too
    hard to go back and componentized the Windows Vista core code. So when it restarted Windows
    Vista development, Microsoft naturally used the Windows Server 2003 with SP1 code base instead
    of that of XP.
    http://news.com.com/2100-1016_3-6075912.html
    "The plan is unlike (Windows) XP and (Windows Server) 2003, where we had separate code bases.
    We'll have one code base," Muglia said. "That will all converge next fall, roughly...when
    Longhorn Server ships."
    As the Vista team patches bugs in the desktop operating system, those changes will be folded
    into the Server code. Meanwhile, the changes to the Server code will be added back into Vista
    in a service pack for the desktop operating system, currently slated for delivery next fall.
    The plan is not that new. Microsoft once hoped that Windows XP--then known as Whistler--and its
    server counterpart would share a common code base. Instead, the company took longer to do the
    server update, in part to revamp its security approach, and eventually shipped it as Windows
    Server 2003.
    -Michael
    "Mark D. VandenBerg" <mvan103@hotmail.com> wrote in message
    news:4D94EDB0-20B1-416B-88DD-8E19B8FE9955@microsoft.com...
    > While XP was an evolutionary redo of Win2000, Vista is a completely new operating system. As
    > such, many things, including drivers, are handled differently. Simply put, just because it
    > works in XP, doesn't mean it works in Vista.
    > I suggest contacting the vendors of your NIC's to see if they have Vista-compatible drivers
    > for their products, or, if they don't, search this newsgroup to see which NIC's have been
    > able to work and then get one of them. Most are relatively inexpensive.
    > Mark
    >> are for win98-2000)
    >> them.?
    >> robin
  4. #4
    <begrudgingly>
    Yes, Michael, you are correct in that Vista is a descendant of Server 2003.
    However, in the context of answering Robin's questions about compatibility
    between XP and Vista for the average consumer, I didn't think it was
    necessary to point this part out. As my ex-wife used to relish, I could be
    wrong!
    Mark
    "MICHAEL" <u158627_emr@dslr.net> wrote in message
    news:ebHFjxPpGHA.4932@TK2MSFTNGP05.phx.gbl...
    > code base than XP.
    > the same code base.
    > Windows version at the time, and today that version is Windows Server 2003
    > with Service Pack 1 (SP1). When Windows Vista development started two
    > years ago, however, it was originally based on Windows XP. In mid-2004,
    > was too hard to go back and componentized the Windows Vista core code. So
    > when it restarted Windows Vista development, Microsoft naturally used the
    > Windows Server 2003 with SP1 code base instead of that of XP.
    > separate code bases. We'll have one code base," Muglia said. "That will
    > all converge next fall, roughly...when Longhorn Server ships."
    > changes will be folded into the Server code. Meanwhile, the changes to the
    > Server code will be added back into Vista in a service pack for the
    > as Whistler--and its server counterpart would share a common code base.
    > Instead, the company took longer to do the server update, in part to
    > revamp its security approach, and eventually shipped it as Windows Server
    > 2003.
    > -Michael
    >> works in Vista.
    >> this newsgroup to see which NIC's have been able to work and then get one
    >> Mark
    >>> fine
    >>> the
    >>> the
    >>> (drivers
    >>> are for win98-2000)
    >>> them.?
    >>> reformat-
    >>> robin
  5. #5
    MICHAEL Guest
    I reckon, your point is correct- Vista did not evolve from
    WinXP, therefore, compatibility between the two with drivers
    and such could be a problem. Which many of us have seen.
    Sometimes drivers from XP work in Vista, many times they don't.
    Or, XP drivers may not work as well in Vista.
    -Michael
    news:90B16DD0-FB0B-4374-A63C-6576D1F9A5E0@microsoft.com...
    > <begrudgingly>
    > Yes, Michael, you are correct in that Vista is a descendant of Server 2003. However, in the
    > context of answering Robin's questions about compatibility between XP and Vista for the
    > average consumer, I didn't think it was necessary to point this part out. As my ex-wife used
    > to relish, I could be wrong!
    > Mark
    >> code base than XP.
    >> the same code base.
    >> bases. We'll have one code base," Muglia said. "That will all converge next fall,
    >> Vista in a service pack for the desktop operating system, currently slated for delivery next
    >> fall.
    >> its server counterpart would share a common code base. Instead, the company took longer to
    >> do the server update, in part to revamp its security approach, and eventually shipped it as
    >> Windows Server 2003.
    >> -Michael
    >>> As such, many things, including drivers, are handled differently. Simply put, just because
    >>> it works in XP, doesn't mean it works in Vista.
    >>> Mark
    >>>> are for win98-2000)
    >>>> them.?
    >>>> robin
  6. #6
    .... and yet I fail to feel any vindication...
    Mark
    news:uNH79WQpGHA.2360@TK2MSFTNGP05.phx.gbl...
    > -Michael
    >> <begrudgingly>
    >> 2003. However, in the context of answering Robin's questions about
    >> compatibility between XP and Vista for the average consumer, I didn't
    >> think it was necessary to point this part out. As my ex-wife used to
    >> Mark
    >>> code base than XP.
    >>> the same code base.
    >>> 2003 with Service Pack 1 (SP1). When Windows Vista development started
    >>> because it was too hard to go back and componentized the Windows Vista
    >>> core code. So when it restarted Windows Vista development, Microsoft
    >>> naturally used the Windows Server 2003 with SP1 code base instead of
    >>> that of XP.
    >>> the Server code will be added back into Vista in a service pack for the
    >>> known as Whistler--and its server counterpart would share a common code
    >>> base. Instead, the company took longer to do the server update, in part
    >>> Server 2003.
    >>> -Michael
    >>>> works in Vista.
    >>>> Mark
    >>>>> fine
    >>>>> sees the
    >>>>> to the
    >>>>> with
    >>>>> (drivers
    >>>>> are for win98-2000)
    >>>>> found
    >>>>> find
    >>>>> them.?
    >>>>> reformat-
    >>>>> another
    >>>>> robin
I need advice on how to get vista to put a driver on for my ethernet card- please help problems?
Windows Vista, no ethernet card, want internet Nemephosis Drivers 10 19 Dec 2008
New Realtek Ethernet Card Driver Released Brink Drivers 4 07 Mar 2008
New Realtek Ethernet Card Driver Released Brink Network & Sharing 4 07 Mar 2008
3 Com Ethernet card driver frequency Drivers 2 27 Sep 2007
New Realtek Ethernet card driver released Brink Drivers 1 20 Jul 2007
