| | Using Dual Monitors - Won't Retain Settings Hello. I have a Dell XPS M1710 Laptop that I carry back and forth to work (where I place it in a docking station). A second monitor is also attached to the docking station. In "Display Settings," I have chosen to make the second monitor my primary monitor, and extend the desktop. PROBLEM: These settings won't save. Every time the screensaver comes on, or I restart the computer, the settings revert back and I have to change them again. Is this a Vista bug, or something I can fix? Any help would be appreciated... this is frustrating. Thanks, Jessi |
| retaining display settings on dual monitors | Vista installation & setup | |||
| settings changed - 3 monitors - maximises window across all 3 monitors instead of 1 | Vista performance & maintenance | |||
| settings changed - 3 monitors - maximises window across all 3 monitors instead of 1 | Vista installation & setup | |||
| Using Dual Monitors - Won't Retain Settings | Vista General | |||
| Dual Monitors don't keep settings after startup | Vista hardware & devices | |||
